any one have one or where i can find one at thanks
BlueZee28
close
I have a complete disc rear end from a 87 camaro, 10 bolt. Has the brakes on it for $250
I'm in St Charles MO, not too bad of a drive from semo.
JamesC
close
Quote:
Just curious, Nick. From all that I can discover, 10-bolts were equipped with Delco-Moraines from 82-86. Are you certain of the year? Sorry about the off topic. Originally Posted by BlueZee28
I have a complete disc rear end from a 87 camaro, 10 bolt. JamesC
BlueZee28
close
I'm not positive that the rear end is original to the car, but I could get a photo of the RPO sticker for you to verify.
JamesC
close
Quote:
If the car is an 87 and the RPO sticker shows J65, I'd be very interested. Your word's good, no need for a pic. Many thanks.Originally Posted by BlueZee28
I'm not positive that the rear end is original to the car, but I could get a photo of the RPO sticker for you to verify. JamesC
BlueZee28
close
The car's a piece of junk so I used my size 14 shoe to kick the center console apart, the lid was cracked pretty badly anyways. Sad thing about it is this car was really a nice car brand new with all these options. It's kamikazeiroccy's old car.
Carfax says it's an '87. I know you didn't need a photo for proof, but maybe this can help someone else here.
Off topic, but do you see an RPO code anywhere that may reflect aftermarket ttops? The tops from this car don't look like other sets i've had in the past, and it has some wierd trim on the roof.
Complete with 3.73's and LCARB's, long studs, and for the right price will include boxed LCA's with alum bushings. It will need a set of sides and spiders, or a posi-unit, as it did have a mini-spool in it.
Tags 10, bolt, conversion, disk, generation
