Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
1986 z28 rim question, help please
Old Oct 1, 2012 | 06:27 PM
xxbrew1690xx's Avatar
Car: 1986/90 camaro
Engine: 350 tpi
Axle/Gears: 3.73 gears. POSI
I have stock 86 z28 rims and i want to widen the rear rims to fit bigger tires but with stock tires, does anyone know of any shops in wisconsin or illinois that will custom widen the tires? with quality work?
Old Oct 1, 2012 | 06:32 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 1986 z28 rim question, help please
I dunno if this place has any locations close enough for you to drive to, but you can always ship your wheels.
I had them do 2 of mine a couple years back & the wheels were great. Never have given me any problems.
http://www.wheelsamerica.com/
Old Oct 1, 2012 | 09:02 PM
Car: 1986/90 camaro
Engine: 350 tpi
Thanks! I want these rims to be wider cause i love how these rims look and ive never seen these rims widened, what rims did you have them do? and how much did you have them widen yours?
Old Oct 1, 2012 | 09:50 PM
Car: GTA
ROH Snypers. I went from 17"x9" to 17"x11".
Were you doing 15"s or 16"s? I ask because there are VERY few 16" tires that need wider wheels than what the stock 8"s are, unless they are pure race (autocross) tires & even then.....Not many.
Old Oct 1, 2012 | 09:57 PM
Car: 1986/90 camaro
Engine: 350 tpi
i have the stock 86 z28 rims they are 15x7 and i want them like 15x9 or 15x10
Old Oct 1, 2012 | 10:00 PM
Car: GTA
Your 9" would be fine (obviously) but the 10" they may or may not do. I think their standard limit is 2", but do widen some wider, depending on the wheel. You'd just hafta ask them or find another place if they won't.
I just went 2" because the extra 1" woulda created way more work for clearance. The extra 2" was "bad" enough.
Old Oct 1, 2012 | 10:03 PM
Car: 1986/90 camaro
Engine: 350 tpi
yeah im keeping the fronts at 15x7 and then widen the backs to 15x9. and i wanna run drag radials, what siz drag radials you think would fit with minor massaging of the inner wheel well lol
Old Oct 1, 2012 | 10:10 PM
Car: GTA
With only a 10" wheel you should have quite a bit of room, depending on what the bs ends up at.
I've never been much into draggin' so I'm not a good source of info as to what width/sidewall aspect works out to. Overall diameter will be your main concern after the bs.
I can tell that in the rear of the wheel well there is a good bit more room than the front. The very front lower corner was my biggest enemy, besides the bumpstop that I had to completely cut out.
With a 15" wheel your be more limited on the bs (i have 7"bs) because it can't fit over things like the bumpstop or the parking brake lever like my 17" could. I had to make a few cuts the the parking brake lever & bend it back for the wheel to clear it.
Old Oct 1, 2012 | 10:14 PM
Car: 1986/90 camaro
Engine: 350 tpi
I greatly appreciate the feedback, im going to call wheels america tomarow and see what they can do and get a quote, i wont have to ship my rims if they can do it, they have a shop only hour and a half away from my house but thanks again for the help and the source, ill post up pics if i get them widened
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
