Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Switching CFI to Carb, HELP!!
Old Oct 21, 2012 | 05:52 PM
hxras1's Avatar
Car: "82" CFI, camaro, "05" vette
Engine: Changed to 350, adding carb. setup
Axle/Gears: 410, posi disc
The car is an 82 indy pace car, put in a 350, and now want to replace the CFI with a carb. I've got the CFI stuff off the car, and the 4bbl intake installed, carb is still in the box. The big question is, all the computer stuff can go, right? The ECM, the harness, ect...? I believe I need to replace the HEI with a non-computer controlled one?? I pulled the whole harness out of the engine compartment, clear back to ECM, now should I buy a different harness, or what should I do to get the thing rewired? It has a 700r4 tranny, how do I wire that up so the converter will lock up??? Many questions, could really use some help.
Thank you in advance!!
Bob
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
stalkier
Aug 21, 2015 01:54 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
