Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Starting issues
Old Apr 28, 2020 | 07:43 PM
Firefighter84's Avatar
Car: 1992 firebird
Engine: sbc 350
Transmission: th 350
Starting issues
Today was start up day but no spark ! I currently have the distributor ran to the fuse box to a hot while key on spot but noticed when being cranked over power shuts off to that fuse. This is a 92 firebird with a sbc 350 carb fed, does anyone know off hand what fuse locations I should look at that will be both hot with key in the on position and also hot when being cranked Thanks!!
Old Apr 28, 2020 | 07:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Starting issues
What happened to the original ignition feed wire ?
This is a pink wire that ran through c100 to the ignition switch.
Old Apr 29, 2020 | 11:56 AM
Car: 1992 firebird
Engine: sbc 350
Re: Starting issues
I have power up to the connection to the cap just no spark to plugs and wires which are new , im really getting confused here lol
Old Apr 29, 2020 | 12:02 PM
Engine: Lb9
Transmission: M20
Re: Starting issues
Bad pu coil, coil , icm , coil wire
Old Apr 29, 2020 | 12:10 PM
Car: 1992 firebird
Engine: sbc 350
Re: Starting issues
This is a brand new distributer
Old Apr 29, 2020 | 12:30 PM
Engine: Lb9
Transmission: M20
Re: Starting issues
Does it have spark when a wire is hooked directly to the battery b+ ?
You could still have a bad icm even in a new distributor.
<CHeVy_GiRL>
Mar 25, 2025 08:56 PM
motoman04
Apr 30, 2015 12:32 AM
al1989
Jul 23, 2012 07:39 PM
sparkplug619
Mar 3, 2010 10:18 PM
ino
Nov 9, 2005 03:06 PM
