I need help....
Old Nov 11, 2005 | 09:28 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I need help....
I am trying to find a shop in nj that can pull my engine and then get a junked 350 and rebuild it as well as swap the auto to t56. I am looking for ONE shop that can do all this as well as order the parts needed.
thanks
matt
Old Nov 11, 2005 | 10:49 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
your better off getting a 350 crate motor than having one rebuilt. the price of machine work alone on the motor and a rebuilt kit will most likely be more than getting a crate 350 at least around here. my frined just had a 350 freshened up and the machine work was a bit more than 1500. not including the rebuilt kit. plus he had the motor already. as far as the t56 swap and shop should be able to do the conversion if you have all the parts.
Old Nov 12, 2005 | 08:01 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
I am not in Jersey but I am right over the bridge in Hulmeville, PA give me a buzz if your interested..
Thanks,
Josh
215-783-4645
Old Nov 12, 2005 | 10:24 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I would not trust just anyone to do this .The end bill could end up being like 10 grand with the parts . Once they have the car you are kind of stuck with them . GET A CRATE MOTOR . If you are not capeable of doing this on your own, put your trust in another TGO meber. Evan if they are a little ferther away . You know you will still end up spending a lot of money if you do not have the parts. Be prepaired to spend a few Grand with new or uesd parts . Good luck and give Josh a call .
Old Nov 20, 2005 | 02:44 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: I need help....
Originally posted by wayfast84.I am trying to find a shop in nj that can pull my engine and then get a junked 350 and rebuild it as well as swap the auto to t56. I am looking for ONE shop that can do all this as well as order the parts needed.
Click here
LVZ2881
Nov 21, 2005 01:11 PM
reilly8282
Jan 14, 2003 09:26 PM
citgofan99
Jan 12, 2002 08:15 PM
