Gear Installers in CT
Old Mar 20, 2007 | 09:00 PM
83-ta-5spd's Avatar
im gettin a set of 3.73 gears and will be buying a basic install kit(pinion shims, crush sleeve, pinion seal and cover gasket), i just need some1 to install them so i kno that they wont whine down the road, i have the rear out of the car, i can pull the axels for the person, i just dont have the tools to install them myself, also i would like to keep it on the low side if possible, im on a budget.
Old Mar 21, 2007 | 04:14 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
Re: Gear Installers in CT
where are you located? also are you doing a posi swap at the same time? I found that alot of transmittion shops will work on axls and transfercases. That would be your best bet for finding a place. I don't beleive that like comutec does it but some of the mechanics prob do on the side.
Old Mar 21, 2007 | 05:09 PM
83-ta-5spd's Avatar
I got a 4th gen z28 rear off TPI hearst, so they are going in there.
Im from the New Milford area, bout 20minz from Danbury
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
camaro11j
Sep 19, 2018 08:49 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
