NYS Emissions Laws
Car: 1985 Pontiac Firebird
Engine: 5.7 carbureted
Transmission: 700 R4
NYS Emissions Laws
I've been a long time lurker, so I thought I might get some posts in. Does anyone have any first hand experience with NY emissions testing? Specifically, I'm wonder about the laws concerning cars that are 25 years or older and so are exempt from any emissions testing during inspection. I'm hoping it means I can run my 85 without a the cat, EVAP, air injection and all that. Otherwise, I'm going to be spending a lot of money buying parts that didn't come with the car when I bought it.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: NYS Emissions Laws
Google your State Laws for emissions, I'm sure theirs separate laws for Historical Vehicles. How old does a car have to be in NY to be classified as Historical?
A lot of it depends on the shop. Some will fail you outright for no cat if it came with one. Others dont care if the car is > 25 years old.
The law is - anything 96 and newer gets tested for emissions through the OBD2 system.
Anything between 25 years old and up to 1995 gets a visual inspection of the emissions system. It is a total BS test and as long as the emissions system like the cats are still there you pass.
Anything 25 years and older just gets a safety inspection. So no one is checking to see if your cat and other pollution control devices are there.
These are the NYC laws and it might be different depending what part of the state you live, but either way no one is checking to see if the cat is gone on your 85.
Originally Posted by Altern881
Otherwise, I'm going to be spending a lot of money buying parts that didn't come with the car when I bought it...
You don't need a smog pump or charcoal canister. However, universal Catco catalytic converters are cheap enough, put one on. I am from New York City, and still drive there all of the time, and they can care less "how old" the car is, if they want to be ball busters they will ticket you for no catalytic converter, or even impound it if they don't see one. Doesn't depend on the area, it depends on the cop. Fighting it does absolutely nothing but waste your time. I run a 3" universal Catco converter, I also have a cutout before it, nobody bothers me even when they see it, and I've gotten pulled over racing quite a few times there...
Originally Posted by 82tarecaro
Cops are not checking to see if you have cats on your car.
I have also been around cars my whole life. You are the only one I have ever heard getting pulled over and gotten their ***** broken for emissions. It must be you.
Racing on the streets is stupid. 2 people just died in California at a street race. You are putting others at risk besides yourself. So call me crazy but if I was a cop and pulled you over for street racing I would not let you off easy.
Engine: 5.0 EFI
Do you NY guys still have MV Inspections with Historical or Vintage registration??
Engine: 5.0 EFI
In NJ you only register your 25 yr.old car once for Historic Plates,no more yearly Inspections no more yearly registrations.
I think here in NY, it would be registering it as a classic. But there are a lot of limitations, how many miles you can drive it, where you can drive it to. I wouldn't think it would work very well for a daily driver.
Keep in mind that if you are running something modified there is a good chance you are going to burn out the cat in a short period of time. Cats do not live long with an overly rich exhaust. You will have to be certain the car is tuned properly, especially if you are running a carburetor. If you are worried about a visual check, there are fake cats that have the appearance of a cat, but inside it is just a straight through pipe.
Here is a link to a fake cat you can buy.
http://www.siliconeintakes.com/dsm-i...cat-p-572.html
1 Post
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
We have numerous old cars in our family.....72 BBC Chevelle a 76 Camaro, a 79 Camaro, a 78 Vette with 19k and my 85 Iroc. The Iroc gets a visual emissions inspection and the other cars get safety only.
The OP can get historical plates, but it's not necessary.
I might go with Street Lethal's advice as well, and put a universal cat on, just to be safe. They're cheap enough...
Smog and Emissions Inspection
Unless your vehicle is exempt, you must complete an emissions test in addition to the safety inspection (see “Requirements and Exemptions” below). The emissions inspection only takes a few minutes, and the types of tests required depend on the model year and weight of your vehicle:
* Model year 1996 and newer gas-powered vehicles less than 8,501 lbs.: On-Board Diagnostic inspection (OBDII).
*Model year 1997 and newer diesel-powered vehicles less than 8,501 lbs.: On-Board Diagnostic inspection (OBDII).
*Model year 1995 to 25 years old at 18,000 lbs. or less: Low-enhanced emission inspection.
OBDII Inspection (1995 & up)...
Part of the emissions inspection is the on-board diagnostics test (OBDII). This is a computerized test that connects to your vehicle to check the emissions system through the vehicle's computer. Your computer controls the emissions output of your engine, as well as a malfunction indicator light (MIL) that illuminates if your computer or your engine is not working correctly.
Low-Enhanced Emissions Inspections (1970-95)...
The low-enhanced inspection is a thorough VISUAL (NOT COMPUTER SCANNED, OR TAILPIPE SNIFFED) inspection of all the emissions equipment in your vehicle, including but not limited to:
* Functional gas cap.
* Catalytic converter.
* Exhaust gas recirculation valve.
* Positive crankcase ventilation system.
* Air injection system.
* Evaporative emissions control.
* Fuel inlet restrictor.
* Thermostatic air cleaner.
http://www.dmv.org/ny-new-york/smog-check.php
Like I said, depending on the COP, and if he or she is a ball buster, they will check for a catalytic converter being that it takes two seconds to look for. He has the RIGHT to ticket you or impound you if one is missing, and if you say "they passed me without one" any shop in their right mind will immediately deny it and say "it was there when they tested the vehicle and the owner probably removed it himself", or they will admit it and be heavily fined...
