Please help. New fuel pump but still problems
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Transmission: Automatic
Short story: bought 89 GTA with supposedly bad fuel pump. Someone had started on replacing by cutting hole in floor and then stopped. I got it and have replaced the fuel tank, sending unit, and fuel pump with a 255 racetronix pump and hot wire kit. Everything is installed but no fuel pressure. I have replace the fuel pump relay too because it was tie strapped together and barely together.
Today
When I unplug the connector from the sending unit and try to run power straight to it with a power probe 3. You here the pump run for a split second and then it trips the power probe. Any thought? Getting frustrated.
Today
Re: Please help. New fuel pump but still problems
Did you cut the hole for the primer in the rubber grommet that goes on the base of the pump? I had a similar issue my pump would prime for the 5 sec I set in the pcm but had no pressure. Like many my pump didn’t have instructions and I installed it like any other pump, but after searching and contacting racetronix I found out about the primer hole in the bottom. I had to pull the pump and cut the grommet. I don’t know why racetronix doesn’t sell it with it already cut.
Engine: 5.7 TPI
