Ohio?
#1951
Car: 1988 gta
Engine: 5.7
Re: Ohio?
Yea its got pros and cons but for under a g thats what u get in ohio.I unfortunately prob not gonba keep ran into financial issues so trying to sell.started fixing electrical isues and tearing out dash.
#1952
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: Ohio?
Edgewater Motorsports Park - Cleves Oh. (near Cincinnati)
Tri-State Dragway - Hamilton (near Cincinnati)
National Trails - Near Columbus
Those are the only ones that I know of in the southern half of Ohio.
#1953
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Ohio?
Looking for an 89 IROC Auto steering column (with VATS) intact. Looking to send my car to a shop with all the parts. Thanks.
#1958
Car: 91RS
Axle/Gears: 373 4th gen
Re: Ohio?
Hey, how's everybody doing. I'm freezing my a** off in Mansfield, dreaming of spring when i can get my Camaro out. I'm looking for an Iroc hood if anybody in the area has one.
#1960
Car: 91RS
Re: Ohio?
Thanks for the fast reply, but a guy local just sold me his hood. Now I'm looking for a spoiler off a 91 or 92 Iroc. A guy in Mount Vernon had one on Graigslist but hasn't returned my text for a couple of days.
#1961
Car: 1988 gta
Engine: 5.7
#1962
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Re: Ohio?
I haven't found anybody to buy just the engine yet. I'll let you know if something changes.
However I do have my lq4 and 4l60e sitting in my garage. Need the old stuff gone so I can get started on the new stuff. Really hoping I won't have to run the old crap until next year.
#1965
Engine: 408 LS
Re: Ohio?
If nobody buys my setup by mid-end of march, i'm probably just going to part it out. If anybody is local and interested in anything, i'll give you guys first dibs.
#1966
Engine: 408 LS
Re: Ohio?
Here is a run down on what i'm going to sell.
-tricked out 113 vette heads - $800 (925 with rockers)
-HSR with kirban AFPR, 30lb red top injectors, rail mounted fp gauge, stock TB - $700
-700r4 with transgo shift kit, vette servo, .500 boost valve, 2500 stall converter - $600
-march underdrive serpentine accessory setup (no smog or ac) - $350
-hooker super comp LT headers jet hot coated and 3 inch custom y pipe (no cat converter) - $550
-proform 1.6 full roller rockers - $150
- 90 SD ecm and custom harness (no smog or ac, parallel dual fans, 90+ style relays and oil pressure switch) - $150
- stock distributor that's been gone through. (new gear, pickup, ICM, msd cap and rotor) - $100
- 355 short block with lt4 hotcam installed (has maybe 6000 miles, all new bearings, gaskets, hyper pistons) - $400
#1967
Engine: 408 LS
Re: Ohio?
Well if you guys aren't interested in any of it, i'm going to start putting the word out that it's for sale. I'm going to start pulling everything this coming week probably. Just got home with my new TEA stage 2 ls6 heads and cam.
#1968
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Where are u located ? ... is the y pipe mandrel bent ? And what diameter
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
#1969
1 Post
Car: 1991 firebird
Axle/Gears: 4.10
I would get the short block too but that'd hard to ship lol
#1970
Engine: 408 LS
Re: Ohio?
I'm located in Ravenna, ohio. The Y pipe is for use with the 2210 long tube headers that have 3 inch collectors. It's also not designed to be used with a cat converter. It's all 3 inch tubing, that was cut and welded together. The bends are mandrel. It also has an o2 bung welded into it, I didn't want the bung put into the headers with the jet hot coating on them.
#1972
Car: 91 Camaro RS,79 Vette, 71 Chevelle
Engine: HELP LOOKING!!!! NEED ONE!!!
Transmission: 700 R4
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Ohio?
Pic of my latest build. Turbo 3.1/3100 hybrid. Who else is ready or getting ready for the racing season to start?
#1974
Engine: 408 LS
Re: Ohio?
I'm getting ready to offload my current setup and get ready to put together my new setup. Hopefully i'll be up and running around may. I'm putting together an lq4 ls motor with the heads i posted, and a cc 54-444-11. I might get rid of the cam for something more boost friendly though. Might also be adding an sts rear mount turbo kit, and running 5-6 psi with that. Not sure if i'm going to try and get the turbo on this year, or hold off until next year and just run it on motor for now.
#1975
Car: 1991 Camaro RS
Re: Ohio?
The new set up uses the top end, heads and up off a gen 3 60 degree V6. Mines off a 2002 impala. The major pros of the set up are the much better flowing aluminum heads, better flowing intakes, and DIS ignition. Called a hybrid because its mixing the older gen1 short block with the newer gen 3 top end.
Also Im making tube forward facing headers. Which are going to be alot better then the log type style I had before. I have the passanger one done already and am going to be working on the drivers side shortly once I get some other things done first on the engine.
#1976
Car: '89 GTA
Engine: 383
Re: Ohio?
Looks really good! So much room to work under the hood of that setup. Do you frequent Norwalk, err, SREMP, most often?
#1977
Car: 1991 Camaro RS
Re: Ohio?
Yea I go every saturday in the spt class at norwalk.
Added a pic of the downpiping. Looks so much better then down pipe ive been running for 2 years...
#1978
Car: .
Engine: .
Transmission: .
Axle/Gears: .
Re: Ohio?
Just dropping by to post a quick hello. Figured there would be an Ohio thread somewhere in here.
Also, this is my first post since joining this board back in...2003. That's got to be some kind of record.
Have always been eyeing these boards since I got an 88 Formula back in the day. She sits, waiting patiently for me to do something with her as she sits in storage.
#1979
Car: 88 camaro
Engine: 2.8l V6
Axle/Gears: unknown/stock
Re: Ohio?
Hey all!! brand new to the forum, but not new to the third gens! im right outside of youngstown. actually in boardman, would love to see a get together in the summer!
#1981
Engine: 408 LS
Re: Ohio?
Man is this place dead. Figured by now people would be getting back into their cars. Sold my tranny, I now have some money to start putting the new motor together.
2500 for all of the rest of my stuff... motor, harness, ecm, headers.
#1982
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: Ohio?
its snowing right now, just saying ^
Last edited by kmcn47; 03-30-2014 at 05:00 AM. Reason: i totally got post 1982, first year of thirdgens baby!
#1984
Re: Ohio?
yeah it did snow, sucks but as stated above, 70 next week end
we actually had snow plow do the street with an inch of snow...and I live on a dead end, i was like really...lol
#1985
Engine: 408 LS
Re: Ohio?
Look at it today, warm and sunny. Still trying to sell all of my thirdgen tpi stuff. Started cleaning up my new motor yesterday, only to find a mark on the #7 cylinder wall. Hopefully it will clean up with a ball hone, if not i'm done until next year.
#1987
Engine: 408 LS
Re: Ohio?
It turns out they are on my side, at least today anyways. A buddy of mine works at an engine shop over in akron, he stopped over and looked at it. He made the mark disappear in no time. I'm picking up the head gaskets, head bolts, timing chain, and lifters this week.
#1989
Engine: 408 LS
Re: Ohio?
Wiring harness, accessories, starter, oil pan with tray and pickup, ls1 intake with fuel rails are all on the way to my house.
Anybody else making any progress?
#1990
Engine: 408 LS
Re: Ohio?
Brought this home yesterday. The turbo is probably too small for what i'm going to do, but it might work. The whole kit is basically complete except for a BOV.
#1991
Transmission: 5spd
Re: Ohio?
i have made none progress on anything to do with my car lol. no progress on the 5.3 swap (been a rough year, very broke) i havent even installed the console clock i bought, its been in the same box it came in for over a year lol. still dont have a headliner. but one of my sun visors fell off lol
#1992
Engine: 408 LS
Re: Ohio?
I went to summit this morning and picked up more parts. Brought home ls9 head gaskets, trickflow chromoly pushrods, taylor wires, ngk plugs, and a big bottle of arp assembly lube.
The new ls7 lifters and arp head bolts are on their way to my house in the mail. Looks like the new motor is going back together next weekend.
#1993
Car: '89 GTA
Engine: 383
Re: Ohio?
Took my car out for the first time the last two days. I put about 120 miles on her for the first time shes really been driven in 7 or so yrs. I made it back in the garage with no issues and a big smile on my face. Now its supposed to snow on Tuesday!
#1994
Engine: 408 LS
Re: Ohio?
Bunch of parts showed up the past two days. Sensors, flexplate, wiring harness, arp head bolts, spark plugs, 4l60e tranny crossmember. Tomorrow should be another day of parts delivery.
#1996
Car: 89' IROC-Z
Engine: LO3
Re: Ohio?
P.S. Sorry CashMunson. I've been quiet about my updates because I've been talking about getting my car out for almost 9 years. I think people are losing faith in me, and I don't want to see them disappointed again when I have to go through another winter using someone else's car, hearing "What happened to the camero" (Not misspelled, this is how everyone pronounces it these days) So, until it's plated and insured, no progress. ;D
#1997
Engine: 408 LS
Re: Ohio?
Sounding like me. Finally getting my car out after nearly 9 years. The finishing touches are being done to get the car road worthy. I'm expecting end of this week or next. I'm hoping the work needed done doesn't bleed into May too much. Expect to see a fellow TGO Member in your area.
#1998
Car: 89' IROC-Z
Engine: LO3
Re: Ohio?
I'm 5-10min from downtown Cleveland. Center of Cuyahoga County.
#1999
Car: '89 GTA
Engine: 383
Re: Ohio?
#2000
Car: 89' IROC-Z
Engine: LO3
Re: Ohio?
Haha, thanks. You're the first I've come across to use it in the same way. Hoping to register them soon. Hopefully nobody will take them, considering every year they've been available...since I've joined TGO Hoping for a fair amount of work to be done on the car next week. Updates soon.
