Northern California Discussion board for Northern and Central California.
Moving to Cali
Old May 6, 2005 | 02:06 AM
85 roc it's Avatar
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
Moving to Cali
I live in Indiana and thinking about moving to Cali. But have a few question, as of now, I have now emission on my car, car is there but hollowed out. no smog pump, no air on headers, no way for an EGR valve, LT1 heads and intake. How strict is the emission laws there, we have none here.
Old May 6, 2005 | 02:22 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Greetings from Cali!
Do a quick search, there are many threads on the California "SMOG ****'s".
Basically an "enhanced" SMOG test with visual and a lo/hi speed chassis dyno.
Not fun.
With no equipment underhood you will fail.
That does sound like one hot combo you have there, I am actually considering the same. How's it do in the 1/4? Custom Chip?
Old May 6, 2005 | 02:41 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Not fun.
Aren't you allowed so much time before you have to have your car checked for smog after moving to CA? I thought it was something like 2 years...
Old May 6, 2005 | 02:50 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Maybe you have a certain time to SMOG it, but its inevitable as far as I understand.
Old May 6, 2005 | 02:57 AM
I realize it's inevitable. It's like death and taxes. In CA you can add smog testing to that list. But at least it would buy him time to set the car up for it and not have to worry about doing it before he left IN. That was the point to my question. Thanks for the clarification...
Old May 6, 2005 | 03:42 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
You're probably right, and I was agreeing with you
I just don't know if he does have time / how long it is.
As "smog-a-phobic" as I am right now, I am thinking Arnold is going to have us all hooked onto a 15MPH treadmill and make sure I'm not a "gross polluter".
Old May 6, 2005 | 10:17 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Once you set up residence,po box,rental agreement,utility bill I think you have 10 or 14 days to notify dmv.You will get a temporary registration card for 30 days and you have to smog it within that time,if it fails you get another 60 days,and I think they will give you one more after that.When you get here I would just get a used running motor,from a wrecking yard or something with all the smog and injection,swap the engines out,smog it and put your old engine back in.It's a lot of work but ou'll get it legal.Something tells me that even if you had you smog equipment on it would still fail.
Old May 6, 2005 | 10:35 AM
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
I have the custom chip in it now, never ran the 1/4 yet, but going to get the prominator. Thanks for all the info, I think I still have all the stuff some where, I'll have to look. How often do they chack the cars
Old May 6, 2005 | 11:23 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Depends on the county.Where I live you only smog when you register for the car for the first time and that's it.La I believe is every year.Sacramento I think is every 2 years.So good luck.Adambros just smogged his 300 hp 355 so it is possible.
Old May 6, 2005 | 12:17 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
It is definitely do-able, I smogged a recently labeled gross polluter 350 with some tuning, tune-up, and a new cat.
Steve has some good recommendations, I am going to do the two motor thing here soon once I get my stroker back. It does depend on the county however, I know lake county and a few other (low population) counties are smog exempt.
Old May 10, 2005 | 12:38 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
The smog here isn't impossible, but it's a b*tch.
Your car won't pass like that. No way in hell. Unless you swap the engines or do something illegal lol.
Old May 10, 2005 | 05:00 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I wouldn't call it illegal ...
Just bending the rules a bit
Old May 11, 2005 | 02:14 AM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Yep, Sacramento County is every 2 years and so is El Dorado County, at least where I live. Kind of wierd Steve, you say you only have to smog when you first register your car and I know you are in El Dorado County, must also go by population numbers within the county. Welcome to CA.
Old May 11, 2005 | 09:14 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Yep,I'm in Eldorado county.I only smog when I first register a car and that's it.If I get a Nevada po box(about 6 miles from my house I don't have to smog at all.I am moving to Gardnerville Nv. at the end of summer anyway so,no smog for me.I'll still keep all my smog and keep it clean though,cough,Travis,Eric,cough.
Old May 12, 2005 | 02:38 AM
Car: 07 Silverado
Moving to NV, lucky you Steve. I also agree with keeping it clean. Never know when you might need that smog stuff, plus when you start taking that stuff off, your car will run funny cause the computer can't find the equipment, your car was made to run with it, and I can't find any real gains in power from removing it. Just my 2
Old May 12, 2005 | 11:59 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
i have no idea what you are talking about -eric
hehehe
anyway well how about this california is 3rd toughest smog rules in THE WORLD wierd eh.... well anyway
on a transfer title you will be a loaded mode test meaning on a dyno with load being put against the engine 15mph 25mph , no matter where you move into ca you will have to smog your car before you transfer states
put all your emissions equipment back on and reconnect air injection we all know the cat is no good without it...
and the most important tip GET A PRETEST dont want to get labeled a gross polluter.
where are you moving to in california
Old May 13, 2005 | 03:01 PM
braindedracefan's Avatar
Car: 1986 Trans Am
Engine: 5.0 TPI 305
Just my ... FYI if you end up having to make repairs to pass smog, if you spend $400 or so (I believe you have to have the shop do it in order to have it verified) then you don't have to pass. They'll defer you for I think it's two years before you have to try again.
Old May 16, 2005 | 09:39 PM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
Re: Moving to Cali
ur screwed
unless u pay the smog guy off
Old May 19, 2005 | 06:57 AM
ron reece's Avatar
Car: 92 B4C/1LE CHP camaro 06 vette LS2,
Transmission: iroc, 700r4, auto
you have 10 days to change your license and registration from the time you move here or have employment.
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
gord327
Oct 3, 2015 01:25 PM
Fanatic1074
Oct 2, 2015 03:47 PM
