Northern California Discussion board for Northern and Central California.
i ran at the track finally
Old Nov 23, 2005 | 02:27 AM
  #51
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
sorry i was replying to tonys post, not yours eric.
Old Nov 24, 2005 | 02:41 AM
  #52
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Originally posted by urbanhunter44
It's not a waste of money terrel, they don't just write down the measurments. Sure you get a peice of paper with all the measurements written on it, but what is important is that those measurements are ACCURATE to within a micron man! It's PERFECT! Engines tend to last under great deals of stress when they're assembled perfectly. Ask any racer or engine builder.
BALANCE and BLUEPRINT are two(2) different things I asked more than one shop and they all said the same thing a BLUEPRINT is just all the measurements of the balanced motor on paper. and Im not gonna pay $75-$100 for a peice of paper
oh!!!!!, travis broke the #8 connecting rod and the piston was broke in half. piston pin was ram'd into the side of the bore and the other end of the rod was wedged between the crankshaft and the top of the block. the driver side head has a little nic but should be ok. eric took pic's im sure he'll post them tomarrow
Old Nov 24, 2005 | 01:28 PM
  #53
JesasaurusRex's Avatar
better or worse than my 355 that we dumped?
Old Nov 24, 2005 | 02:07 PM
  #54
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Originally posted by porkyzilla
whos to say that...none of the parts he put on or the 315hp he had didnt blow his engine
about the only thing bad id say that caused some failure is the fact that you put a new headgasket/lower compression on an old bottom end. so id say its the new cylinder pressures it couldnt take. the other problem is his spring pressure was far too great for his setup.
putting in a cam wouldnt cause a bottom end failure unless there was clearance issues.
Oh yes it can. The cam itself won't do it, I.E. if you put a stock replacement in you'd be fine, but the increased stress from an engine that already has it's wear patterns clearly defined and is just old in general can VERY easily break from it. And your theory may have contributed definetly. But the fact was he changed from stock, and the motor was used to something different. It might have ran for another 30k just fine. Fact is if he had left the CR stock, it still would have broke.
Otherwise you would see people pulling motors out of junkyards to put cams in. For that matter, you wouldn't advise me with 160k to put a heads and cam on my car? Most certainly not. It would die in a month if I was nice to it. However a fresh stock rebuild of my bottom end, B&B'd, will easily handle the 410 hp kit I want.
Yes I'm aware they're two different things. My father has owned a shop for ten years, and we've done more than a few blueprinted motors so I should know. And look at it this way, from your point of view that's EXACTLY what they're doing. But if they're a competant shop, are they going to hand you a peice of paper with incorrent measurements? No. They're going to hand you one with perfect measurements, and that's what blueprinting is.
Old Nov 24, 2005 | 02:11 PM
  #55
i put heads/cam/intake/carb on my 305 comin up on 170k when i still had it
Old Nov 24, 2005 | 02:15 PM
  #56
Car: '72 Chevy Nova
Transmission: TH350
How long did u drive it till you dumped it for the 355 and how hard did you whomp on it? What was it's eventual failure?
Old Nov 24, 2005 | 02:24 PM
  #57
It actually never really completely failed, the crank key that held on the sproket broke off. But that basically ment pullin the motor anyways to get to it easily what not so i just yanked it and threw it away
Old Nov 24, 2005 | 02:38 PM
  #58
I got on it a lot probably, was my daily driver, and thats when i still thought it was fun to beat r*cers
Old Nov 24, 2005 | 02:48 PM
  #59
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
It stopped being fun!?
I didn't get that memo...
Old Nov 24, 2005 | 08:07 PM
  #60
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
yikes.
you sure didn't get to enjoy your newly made power much huh.
what's the plan now?
Old Nov 24, 2005 | 08:12 PM
  #61
kairles's Avatar
Engine: 383/LGX
he's gonna build or buy a short block. He sent me a text message earlier today and said he may have found a 383 for cheap.
I sure it'll be running in about a month
Old Nov 24, 2005 | 08:33 PM
  #62
kairles , check ur pms
Old Nov 24, 2005 | 08:38 PM
  #63
Car: '89 GTA
Must be nice to be able to spend that much time and money on your ride.
Old Nov 24, 2005 | 10:31 PM
  #64
Cali Z's Avatar
Do you think it's possible that running nitrous had anything to do with the problems that developed now? Just a thought.
Old Nov 25, 2005 | 02:44 PM
  #65
Car: '72 Chevy Nova
Transmission: TH350
it certainly didnt help robby, but probably wasnt a major factor if he used a window switch and had the fuel properly adjusted.
Old Nov 26, 2005 | 01:40 PM
  #66
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
woot got my motor, 383 stroker i rule
Old Nov 26, 2005 | 03:25 PM
  #67
oh and Trav, when somebody text messages you on your phone and wishes you a happy thanksgiving, instead of saying "i dont know this number who is this" would be more polite to just say "have a happy thanksgiving as well, or happy thanks giving, etc etc". Tard face
Old Nov 26, 2005 | 04:49 PM
  #68
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
lol im with traviz on this one i was like i have no idea who this is hahah
when i got my text.
Old Nov 26, 2005 | 09:49 PM
  #69
Car: '72 Chevy Nova
Transmission: TH350
i knew, but i didnt get his text till friday morning stupid nextel.
Old Nov 26, 2005 | 11:46 PM
  #70
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
sorry jesse, was this a message you sent to everyone, coulda gave me a hint. im gonna store that number now and put your name on it.
Old Nov 27, 2005 | 01:25 PM
  #71
Think id only send it to you? You're not special
Old Nov 28, 2005 | 07:03 PM
  #72
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
383 stroker, sweet Travis. 12's are in the bag for sure, just going to have some traction issues. Either way it's going to be sweet, hurry up and get it done, lol. Let me know when you need some help. Oh, I love the modified sig, blowed up, that's awesome, nice way of keeping it updated, lol.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
fasteddi
Sep 10, 2015 09:32 AM
Jlanz55
Sep 6, 2015 03:05 PM
Amillionoh7
Sep 5, 2015 11:44 PM
