Northern California Discussion board for Northern and Central California.
comp dropped the ball
Old Feb 7, 2006 | 09:53 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
so the shop was degreeing in my cam (eric-read) and the cam was supposed to be +4 degrees, and it was dialed in dot to dot, and it was -8 Degrees, thats a 12degree difference. their tolerance i heard is a max of 6 degrees +/- so this is double what they allow.
good thing im having it dialed in. otherwise i would have had a real sloppy engine. instead of sending the cam back to comp and waiting another 2 weeks for another cam. I purchased a 9keyway adjustable timing chain set. when that arrives, the shop can bring it back up to where its supposed to be. and i can be good to go.
if it wasnt for this problem, my engine would have been done today. now it will probably not be done till friday or so.
Old Feb 7, 2006 | 10:21 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It's not like I build engines daily or anything, but that really seems excessive for a shelf grind.
Old Feb 7, 2006 | 11:47 PM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
That sucks Travis, at least it will still be done this week though. Besides, if you rush the job it will end up like crap and fall apart like Eric's car, lol. Let me know if you need any help, I have the next 2 weekends off. Keep me updated bish.
Old Feb 8, 2006 | 12:03 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
is a custom grind cam not off the shelf.
I would send it back and let them have it
Old Feb 9, 2006 | 02:18 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
they would hassle about it and take too long, if i just get the timing set, its an easy fix, i just wont recommend comp anymore.
or if u must buy comp, do yourself the favor and have it degree'd
Old Feb 9, 2006 | 11:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only time I had a problem with a Comp product was when I received one bad roller lifter in a set of 16. They FedEx'ed a new one out at their cost and never asked for the defective one back.
Old Feb 10, 2006 | 12:02 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Out of curiosity, you don't have any core shift, do you?
Old Feb 10, 2006 | 12:05 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
what is core shift?
Old Feb 10, 2006 | 12:08 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
When the block is cast, the sand cores can shft sometimes, so the position of the cylinder bores, cam, etc. can vary.
Old Feb 10, 2006 | 12:28 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
umm i dont think so.
Old Feb 10, 2006 | 12:35 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If the cam centerline is shifted to one side, then a roller lifter won't touch the cam lobe at the expected spot and the measured timing can be off. Most blocks are shifted to some degree unless they've been blueprinted. Usually it's minor though, and the lifter bores should still be aimed at the cam centerline.
Old Feb 10, 2006 | 12:52 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
dont know about that, The motor is being put together at a local reputable shop, so I dunno.
Thirdgen89GTA
Oct 19, 2015 09:27 AM
Jorlain
Oct 8, 2015 01:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
sandman92084
Sep 12, 2015 10:27 PM
