Northern California Discussion board for Northern and Central California.
Wierd noises
Old Feb 13, 2006 | 10:51 AM
-89ca/\/\aroRS-'s Avatar
Car: '89 Camaro RS
Engine: 305 tbi
Wierd noises
when im driving and i let off the gas my car starts making a weird noise...but when i give it some gas i dont hear it anymore.....any ideas on what the problem could be and how much it would cost to fix....one of my buddys says it could be that my drive train is out of wack and needs a new baring or something. well any info would help thanks
Old Feb 13, 2006 | 11:15 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
can u be more describtive of the noise? it could be a lot of things
Old Feb 13, 2006 | 11:18 AM
Car: '89 Camaro RS
Engine: 305 tbi
sounds like a low thumping. probably thumps 3-4 times a second
Old Feb 13, 2006 | 11:43 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
check u joints?
Old Feb 13, 2006 | 11:53 AM
Car: '89 Camaro RS
Engine: 305 tbi
i havent checked anything im at work, im going to have my buddys look at everything after i get off
Old Feb 13, 2006 | 12:30 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
u joints is a definite possibility.. could be early signs of rear end takin an early retirement.... can u hear or feel what part of the car its comin from?
Old Feb 13, 2006 | 12:31 PM
Car: '89 Camaro RS
Engine: 305 tbi
the back is all i can say at the moment. ill have more info on the problem soon
Old Feb 13, 2006 | 10:16 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
sounds like u joints
Old Feb 13, 2006 | 10:20 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
U joints, but definitely check your torque arm / panhard / rear suspension while ur under there.
Old Feb 13, 2006 | 10:43 PM
r1maniac's Avatar
Car: 2006 yamaha r1 50th anniversary
Engine: 1.0 ;)
ive had cars come into my shop that were missing a couple of pinion teeth and only made a thumping noise on decel or when you use reverse. check that and like everyone said check your u joints and rear suspension
Old Feb 14, 2006 | 10:19 AM
Car: '89 Camaro RS
Engine: 305 tbi
what about the C clips that hold the axil in place...could it be those?
Old Feb 14, 2006 | 02:17 PM
r1maniac's Avatar
Engine: 1.0 ;)
no if the c clip was broken when you turn the corner your axle would fly out. it would also have nothing to do with the noise only coming on in decel.
Old Feb 14, 2006 | 02:24 PM
Car: '89 Camaro RS
Engine: 305 tbi
im just going off what my mechanic said
mud runner
Nov 2, 2015 07:30 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
