Northern California Discussion board for Northern and Central California.
Brake Question
Old Feb 23, 2006 | 08:39 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Brake Question
Some shadetree mechanics on another forum are telling me that if I convert from drums to disk I will need a new master cylinder in addition to the proportioning valve.
Is this the case?
Old Feb 23, 2006 | 08:40 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
No,otherwise you would need it when you do an axle swap.Just the prop valve.
Old Feb 23, 2006 | 09:49 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
new master cylinder wtf
Old Feb 23, 2006 | 10:04 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Re: Brake Question
ghey
Old Feb 23, 2006 | 10:11 PM
Cadillac's Avatar
I mentioned that the disks take less hydraulic pressure to operate (therefore the proportioning valve) but they responded saying it was more an issue of volume of fluid as opposed to pressure. At least a few of them own their own shps so I gave it a little creedence.
They mentioned that if I did need a new MC, it would be pretty obvious after installation... pedal would be way off and stuff.
Old Feb 23, 2006 | 10:18 PM
JesasaurusRex's Avatar
i actually just did this swap fairly recently, pain in the *** first off all so be sure u wanna do it, second still useing the same MC, front brake line after the master cylinder going into a line lock then T-ing off too each side, back brakes from MC going into an ajustable wilwood prop valve then back to the rear end and T-ing off to each side hope that helps...oh and LT1 discs in the rear if that was in question, they DO clear stock wheels however i had to grind a little off the caliper to fit my 15x9 5.5bs weld draglites on.
Old Feb 23, 2006 | 10:28 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
The diaphram in the disc prop valve is bigger than the drum.I think the drum valve is like 0.75 and the disc is 1.00.I'll have to find the specs but that's about it.
Old Feb 23, 2006 | 10:42 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes and no, the shadetrees are correct depending if GM has two different MC's (they used to long ago). DB's need more volume and usually have a larger bored MC's.
In the"old days" it was a must, but may not be the case now if the same MC is used on 4w DB, etc.
Everything aside, the way Jessae did it is probably the best, since the front to rear bias on the PV's we have in our 3rdgens suck, plain and simple...assuming the MC can hold enough fluid when the pad wear.
You don't need a different/larger MC, as long as there is sufficient volume in it to keep fluid in it after the pads wear down. Adjustable valve will be your best friend when you convert.
Old Feb 23, 2006 | 10:55 PM
Cadillac's Avatar
Where did you get the Wilwood prop valve? How much was it?
How does the adjustment come into play?
Old Feb 23, 2006 | 11:11 PM
Summit, like 30 bux, theres a ****...ill even find a part # for u gimme a sec
Old Feb 23, 2006 | 11:12 PM
WIL-260-8419
on summit... enjoy
Old Feb 23, 2006 | 11:52 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I have one of those in my Firstgen and hate it because it leaks.
I'd tell you to find a disc rear car at your local junkyard and pull the proportioning valve. Install it in your car and have factory fit and NO LEAKS!
Old Feb 24, 2006 | 01:37 AM
really im having no problems with mine (knock on wood ofcourse)
Old Feb 24, 2006 | 01:53 PM
Cadillac's Avatar
Thanks Jesse (and Vin). I'd love to get a GM original one but have heard they charge upwards of 100 bucks for a new one. The Wilwood is an attractive option however (name and cost).
If I knew my way around these cars like some of you gents, the junkyard option is the way I would go.
Old Feb 24, 2006 | 02:56 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Just find a disc rear car in the yard, follow the lines to the prop. valve (metal block looking thing) and you could have it out with a Crescent wrench (although I would recommend flare nut wrenches) in a few min.
No lines to bend for an adjustale, no headaches, no stealership price tag.
Old Feb 24, 2006 | 04:33 PM
Cadillac's Avatar
Hey Terrell, you reading this?
Will you need your old prop valve on that 10 bolt?
Old Feb 24, 2006 | 06:27 PM
ratrodjon's Avatar
Car: 89 CAMARO, GUTLESS WONDER
Engine: 305 TBI
I think these guys are thinking of older front drum to disk conversions where fluid cunsumption was a much bigger difference than with the rear axle wich takes much less effort to stop. All the rear axle disk conversions kits i've seen do not include new master cylinders. On a different note I would rather upgrade the front disks and leaving the rear alone (rotational drag)
Old Feb 24, 2006 | 06:33 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Actually you do need the master cylinder too for optimum performance.The piston bore for the disc brake is 1.00" and the drum 0.75".
Old Feb 24, 2006 | 06:56 PM
Cadillac's Avatar
Well dang.
Otimum performance is what this is all about for me. Would this do the trick?
Ebay auction
Is that the valve I need too?
Old Feb 24, 2006 | 07:39 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Yep,that's the master cylinder and the prop valve.I forgot that I swapped the master too.I took it off the 86 t/a that Eric now has.It wasn't out of poket so I forgot about it.
Old Feb 27, 2006 | 10:29 AM
Cadillac's Avatar
Well, I won that auction. 25 bucks for a master cylinder with OEM prop valve. Not too bad if it's in good shape.
Now for the speedo gear and my stock to hit a decent price.
Old Feb 27, 2006 | 12:30 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Sweet!I have to do my rear swap asap as my driverside rear wheel is knocking around (bearing)No point in fixing that just to swap it later.I'm leaving on the 7th for vacation in Florida for 2 weeks so I'll have to do it when I get back.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
