Northern California Discussion board for Northern and Central California.
freakin lt1
Old May 4, 2006 | 01:07 PM
TMoNeE's Avatar
Car: 87 Z28
freakin lt1
So im putting my tr-6 plugs in... i got my drivers side in, which was a pain in the ***.... but i have no idea how im going to get to the passenger side ones without removing a bunch of ****... :sigh: so we'll see when get a chance to do it, but its going to be a pita
Old May 4, 2006 | 08:02 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
got any pics? is it worse then an lt1 in a 4th gen?
Old May 4, 2006 | 08:17 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
You should see the vette lol, I have no CLUE how my dad is gonna change the sparkplugs in it... i can barely see the plug boots!
Old May 4, 2006 | 08:24 PM
TMoNeE's Avatar
Car: 87 Z28
i dunno, i never worked on a 4thgen lt1.. i wont be home til after 9 but ill take a pic when i get home so you can get an idea of the mess im going to have to deal with haha
Old May 4, 2006 | 09:16 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Pull the Y-pipe and alternator Just be sure to soak the bolts on the header flange with PB Blaster or similar, and work them loose (try tightening them first to "break the seal"). It's EASY to snap studs on these.
I've got my driver's side manifold out of the car and the passenger's side is almost out (putting in my LTs) and I'm just doing all the plugs and wires now while I have a chance
Doing it isn't bad in a 4th gen, if you pull the Y-pipe the passenger's side becomes easier. It's possible to get them from the bottom with the Y-pipe on but it's ridiculously hard.
Old May 4, 2006 | 11:52 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Everything fourth gen oriented has that phrase attached to it.
Old May 5, 2006 | 03:50 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
Old May 5, 2006 | 04:21 AM
Car: '72 Chevy Nova
Transmission: TH350
That's just what non-4th gen owners think Some things are unnecessarily hard, but alot of things are the same.
Old May 5, 2006 | 04:51 AM
JMJ2003's Avatar
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Tim, if you get too frustrated and pissed off w/ the Camaro, let Ellen drive it. Just make sure you have full coverage. hahahahahahahahahahahahahahaha
Old May 5, 2006 | 05:10 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
lol.... Ouch.. just because ellen cant defend her self on TGO anymore doesnt mean we can keep Bashing her....
Old May 5, 2006 | 11:27 AM
TMoNeE's Avatar
Car: 87 Z28
well, it turned out to not be so bad.. i didnt have to remove anything.. the plugs are tough to get to... but each one has an angle with a little room.. so i used a go thru socket for the plug and an adjustable head ratcheting wrench and was able to get them done this morning... took like 45 min for the pass side. 1 from the top, 3 from the bottom... done deal.
Old May 6, 2006 | 12:09 AM
Car: '72 Chevy Nova
Transmission: TH350
I took out my passenger's side plugs in about ten minutes today, with the Y-pipe out. It really isn't hard on a 4th if you get rid of that thing.. My dad had a nifty socket to help do the plugs with the headers on.. it's got one side missing so you can slide it onto a plug from the side. Really slick! Course I won't need plugs for another 100k now
of course, I've already got the driver's side long tube in and the passenger's side manifold is out of the car and the other one goes in tommorow morning. Then I get to enjoy open headers all weekend till i can get her to the exhaust shop in the morning on monday.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
