Northern California Discussion board for Northern and Central California.
Since most of the Sac crew knows...
Old May 28, 2006 | 05:20 PM
  #51
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
how much is the car lowered?
unless i was racing it, i wouldn't care to correct the geometry/center of gravity.
when i think of a panhard, i think of it more for lateral movement (auto-x) or for aligning the rear for bigger tires.
what's in all those boxes??
Old May 28, 2006 | 09:12 PM
  #52
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I couldn't tell you how low it is but its low, theres no fender gap in the front and hardly any in the rear
boxes: seats, rims, intake, exhaust(for my bike), the red thing is an genIII engine stand, I added the turbo and some little stuff. plus the tires for the T/A are there now, and my moms old rims off the vette. they wont fit anywhere in the garage with 2 bikes and 2 cars. plus the 2 engines tool box and the engine hoist
Old May 29, 2006 | 02:14 AM
  #53
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Glad to see the GTA is coming around, she looks good bro!
DEFINITELY get the wing before she gets painted, it will be a brand new car after that
Old Jun 15, 2006 | 06:47 PM
  #54
kairles's Avatar
Engine: 383/LGX
update.........phone pics
pretty much finish with the TA now I should get it back early next week. had a bad IAC, TPS, and TPS connector. Then I just need to change the plugs, cap, rotor, have the tires put on, oil/filter change and I'll be ready for tahoe.
trans cooler
trans and torque arm mount. I have a small oil leak
UMI LCA relocation brakets. they are semi welded(not in this pic) now but bennie ran out of gas, thats why Im gonna pick it up early next week. can also see the lakewood adj. panhard
Old Jun 15, 2006 | 08:06 PM
  #55
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I love looking at pics like this. Good quality on the phone too.
Old Jun 16, 2006 | 01:06 AM
  #56
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
yay
lets race.
Old Jun 20, 2006 | 01:43 PM
  #57
kairles's Avatar
Engine: 383/LGX
went and picked up the TA today, LCARB are still not fully welded gonna go back on thursday to finish them. also checked the fuel pressure, all I can say is DAMN!!!!!!!!!!!!!!!. was set at 58psi backed it down to just under 50psi(took forever to do so). tires go on tomarrow morning then I'll change the plugs/cap/rotor, and wait for my K&N
Old Jun 20, 2006 | 11:50 PM
  #58
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
you need a fuel pump. that's probably why he cranked up the pressure so high to compensate during hot start up.
Old Jun 21, 2006 | 12:24 AM
  #59
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
hey benny can we still hook up in a few weeks maybe to play with my afr?
Old Jun 21, 2006 | 01:08 AM
  #60
kairles's Avatar
Engine: 383/LGX
got to really get on it kinda. on my lunch break I went to the bank and decided to floor it down freepart. got it up to about 96mph it pulled pretty good. then it didn't wanna start back up. now I really do think its the fuel pump. I couldn't hear it priming when I turned the key.
hope your right I still wanna drive it to tahoe so get it done FAST.
then I was gonna push it into the shad hoping it would cool quicker. mom turns the wheel then *POP* WTF was that? she gos to turn the wheel and it effertlessly turns in circles and the wheels don't move. turns out the the splines on the grant install kit are striped, the main nut had back just about all the way off and the threads in the little "Y" thing are all stripped
this is how it sits now
gonna get a kit in the morning and through it on then hopefully get the no hot start problem solved in to to make it to tahoe
Old Jun 21, 2006 | 03:41 PM
  #61
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
Good thing that didnt happen while u were driving it.
Old Jun 21, 2006 | 11:35 PM
  #62
kairles's Avatar
Engine: 383/LGX
yeah thats what I was thinking
Old Jun 22, 2006 | 02:00 AM
  #63
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
i put my steering wheel on like 90 degrees wrong if that counts lol today i threw it on in a hurry trying to get to the track at a decent time..
the funny thing is that it was just the really worn ignition lock cylinder causing the oil pressure gauge to go wacky works fine now
and i discovered after i was finished that my "spare" column turn signal lever is broken
ill put my oricnal column back together and put it in there lol
crucial
Nov 16, 2001 01:25 PM
Roshambo
Sep 12, 2001 11:31 PM
redcamaro83
Jul 24, 2001 08:41 PM
fly89gta
Jun 22, 2001 07:14 PM
