Northern California Discussion board for Northern and Central California.
Need some help!
Old May 30, 2006 | 06:14 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
Need some help!
I just installed a holley afpr and the wheel on the fpr is hitting the plenum. Do i grind some metal off the wheel or off the plenum? What tool should i use? And is there a better way?
Old May 30, 2006 | 07:02 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
grind the medal on the plenum. Thats what i had to do on my 89. All i used was a file. It took some time but it evenutally worked.
Old May 30, 2006 | 08:22 PM
G-Ride14's Avatar
Car: 1988 GTA
Thanks. I'm bout to go do that right now
Old May 30, 2006 | 09:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
what wheel are you refering too? the adjusting screw?
Old May 30, 2006 | 10:38 PM
G-Ride14's Avatar
Car: 1988 GTA
yea the adjusting screw. i got it to fit. just used a file
Old May 30, 2006 | 11:03 PM
Camaero's Avatar
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
That is strange... it fit just fine on my 87.
Old May 30, 2006 | 11:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thats why i asked, fit fine on my plenum too. probably just had it screwed out too far?
Old May 31, 2006 | 12:15 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
the holley afpr is different from most. It has a wheel(the top of the afpr) that you can turn with your fingers, in place of a screw. I think maybe the rails are not bolted down all the why, or something
Old May 31, 2006 | 02:36 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
mine fit fine to, no grinding needed
Old May 31, 2006 | 11:58 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
oh i got ya. still weird it wouldnt clear, i think terrell is correct.
Old May 31, 2006 | 01:12 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
on my 89, when i put my holley afpr, when i screwed it all the way down it would clear my plenum. If i turned the **** 1/4 up it will start hitting the plenum. since i wanted maximum adjustability i took off my plenum and grinded it down a bit. And everything was bolted down correctly. G-ride , just grind the plenum.
Old May 31, 2006 | 11:26 PM
G-Ride14's Avatar
Car: 1988 GTA
When i put everything back together i had plenty of room but before i bolted the plenum it looked like it wasen't going to fit. Car fired up fine but now i got to fix a leak on my smog pump.
Old Jun 1, 2006 | 12:22 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
only proper way to fix it is to remove it!
