Northern California Discussion board for Northern and Central California.
Progress
Old Sep 11, 2006 | 04:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Progress
Finally got my engine to run without throwing a code or having 20 degrees of knock retard. Which was my problem all along since the ecm swap. Now I can actually get into the tuning portion properly. Next mod: Exhaust.
Old Sep 11, 2006 | 05:02 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Right on man!
You clean that air filter yet?
Old Sep 11, 2006 | 08:59 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Good idea, I'll make that my next mod instead.
Old Sep 11, 2006 | 09:30 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
about time....now pop that 12's cherry
Old Sep 11, 2006 | 09:34 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
That's great man.
Was it just the incorrect knock sensor that I read in the PROM thread causing you the problems?
Are you going to give it another go on 9/20?
Old Sep 11, 2006 | 10:57 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
It was actually the external knock filter that maf uses, while the SD unit has it internal, so the knock single was passing through two 'filters'. Funny that in my research for the swap I never ran across that portion of it. All I had to do was unplug the two wires from the external filter and mate them together. I was curious as to why when I backtracked my rewiring that the knock sensor wire was white, but where it pinned into the ecm , the wire was black. lol.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Cornholio7979
Sep 20, 2018 02:31 AM
gta power
Convertibles
Sep 23, 2015 09:32 AM
sailtexas186548
Aug 26, 2015 03:32 PM
1985chevydude
Aug 22, 2015 05:36 AM
