Northern California Discussion board for Northern and Central California.
Never goes as easy as you think: LS1 Brakes
Old Nov 11, 2006 | 09:16 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I got Ed's LS1 brake kit from Fort Mill, SC early this week and have been thinking about the install for a while now. We started last night before the rain. Anyway, we noticed that the driver's side ball joint on the A-arm looks to be original and the threads on the bolt are looking cross threaded.
So after putting the passenger's side on without any problem (the kit really is bolt, bleed, and go) we were trying to decide what to do with the driver's side. Obviously getting the ball joint out of the A-arm is the beyotch now especially when we are looking at the spring being there (and no spring compressor). I can already tell that if we get the A-arm off, the bushings in there are also going to be original equipment and may even disintegrate when we get to them.
To make a long story short, I think I am going to suggest we put the A-arm back together and then slap the spindle on the ball joint. Maybe the pressure of the spindle will hold the bolt enough we can use another nut to die the threads back to normal. If that doesn't work, we're back to removing the a-arm and getting a spring compressor (dang it!). If the shortcut works, I will still need a new ball joint and chassis bushings later but that is work I don't want to do.
Brakes look awesome though. Big ole, free-floating disks with dual piston calibers make the old brakes look anemic as hell.
Old Nov 11, 2006 | 09:57 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
you don't "need" to use a spring compressor to remove the front spring, just slide a pole up the center of the spring from the bottom (this keeps the spring from going anywhere) and carefully pop it out with a pry bar.
Old Nov 11, 2006 | 10:37 AM
Cadillac's Avatar
A pole?
How do you reinstall it after that? I'll rent a spring compressor I think. Man, I'm bummed.
Old Nov 11, 2006 | 12:53 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
BE VERY CAREFUL! Those things have a lot of potential energy. Enough to knock you out or even kill you. If you've never done it before, find someone who has and talk to them for advice.
Old Nov 11, 2006 | 03:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Hey Mike, Will and I just did the springs, For safety, Use the compressor,
Old Nov 11, 2006 | 05:00 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
this one time i pried springs out of a car at pnp it was sweet when it shot out not very much energy although the a arm was half dropped.
Old Nov 11, 2006 | 10:28 PM
Cadillac's Avatar
Got it out with the compressor. Had to cut the compressor screw by 2 inches to get the thing back in though. After the spring, getting the new ball joint unpressed and rpessed was needed and then install with the sway bar was a snap. We installed the spindle without remark, bled the brakes and prepared to add the wheels when it was apparent that we needed a spacer to make the GTA's pass the caliper.
I called Ed and he told me he forgot the GTA spacer that was required and gave a factory part number he was going to express ship on Monday. In the meantime it sits in a garage (doesn't get to do this often) and waits for the delivery.
Everything with the brake install was as advertised. The components look awesome and after looking at the OEM stuff that was there with the cracked brake lines, I would simply recommend Earl's brake lines for factory replacement.
Anyway, the spacers would have made it driveable tonight (Kragen, Pep Boys didn't have the spacer I needed). I know the performance will be worth waiting for.
Attached Thumbnails Never goes as easy as you think:  LS1 Brakes-p1010864.jpg   Never goes as easy as you think:  LS1 Brakes-p1010859.jpg
Old Nov 11, 2006 | 10:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Very nice. Purdy.
Old Nov 11, 2006 | 11:15 PM
Cadillac's Avatar
OMG... it's killing me that I have to wait.
Old Nov 12, 2006 | 12:52 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Looks good... Must wait!!
Old Nov 12, 2006 | 04:43 AM
Zepher's Avatar
Looks great..
Old Nov 12, 2006 | 03:58 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Without sounding retarded, what is your purpose for choosing this kit? Wieght, performance, cost? Just curious. I know (with my obsession with wieght) I will always look at these 3 things in this order. I have heard good things about Earl's Brake Lines too. My IROC came stock with 4 wheel disc brakes. So for me to upgrade I will have to go with a bigger rotor (front and rear) and a lighter (aluminum) caliper. Is Baer and SSBC all about the same? Sorry,I didn't mean to jack the thread.
Old Nov 13, 2006 | 02:18 PM
TMoNeE's Avatar
Car: 87 Z28
Looks great..
Holy sh|t, you're still alive! Whats up man
Old Nov 13, 2006 | 02:34 PM
Owl_'s Avatar
Car: 1987 Z28 Camaro
Engine: LB9 V8 305-cid
Transmission: 4 speed automatic - 700r4
Axle/Gears: stock - 2.73 rear end
They look...
awesome!!!! I'll have to come over and have you do mine!!! LOL
Old Nov 14, 2006 | 12:31 AM
Cadillac's Avatar
Well, obviously price was not a consideration so I went with this forum's most praised brake builder. He puts these kits together in South Carolina and has either installed or shipped them out to many TGO members so basically, the recommendations were hard to ignore. This guy knows what kinds of brakes and calipers fit on our cars so I went with him. He even made a kit using Cadillac brakes off the new XLR's!
~shrug~
All I know at this point since I haven't driven it yet is that the rotors sure are a bunch larger.
And Owl... I'll certainly watch while you do yours. If you don't have to replace a ball joint, it's actually not real hard (if I can do it).
Old Nov 14, 2006 | 12:48 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
[/QUOTE]
What's the diameter difference of the rotor in the new ones vs. the stock ones? Can you shoot me a link? Can you get them slotted? Are the calipers alum? Will they work with factory OEM 16" wheels? When I put 22's on my wifes Tahoe, we chose a Baer kit that made a 14.? rotor for the front and changed the rear drums to a 13.? rotor in the rear. Looks cleaner and obviously stops better.
Old Nov 16, 2006 | 10:47 PM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Man, those stock brakes do look tiny compared to the gigantic rotors!
I did mine some years ago but went with the Baer kit. Wish Ed was around back then, I would have probably bought his kit over the Baers.
Looks awesome though man!
BTW Caddy, when we goin mountain biking?
Old Nov 16, 2006 | 11:00 PM
Cadillac's Avatar
Friggin' show off!
We'll go MTB when I get off my lazy **** and back into shape.
Where you been?
Old Nov 17, 2006 | 06:33 PM
Cadillac's Avatar
Well, I got the spacers on and thus the wheels.
What a difference.
Old Nov 17, 2006 | 08:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I want to go mountain biking
Old Nov 17, 2006 | 08:53 PM
Mr. IROC-Z's Avatar
Let's do it man...me, you and caddy!
Anyone else?
We can meet up somewhere in the middle and do a day ride.
Tommy
Old Nov 17, 2006 | 08:56 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I live kinda far, and I have no way to transport my bike. I appreciate the offer but I don't see it as very feasable.
Old Nov 17, 2006 | 09:38 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
great job Mike!! I bet it feels way better than those little 10" brakes huh?? Post some pics with them on the car. Since were showing each other brakes then why not...
Attached Thumbnails Never goes as easy as you think:  LS1 Brakes-brakes.jpg
Old Nov 17, 2006 | 09:39 PM
Cadillac's Avatar
I'll MTB less now that the rain is here but I got a road bike too. Either way, I need to get my butt back in the saddle.
Travis: Get a Hollywood FS1 for your Camaro. Approved and tested by your truly:
So yeah, the brakes rock. I can totally lock down the car at will now (couldn't before) and it's not that that is a good thing. A problem cropped up after the alignment though. When I turn the wheel to the right at about 60% of the turning the radius the wheel starts to hit the wheel well and at this point the wheel has caught one of the fender bolts and has pulled it out a ways. I'm afraid the curb I hit a year back (or more) has bent the frame enough to affect the wheel's position in the well in addition to the turning radius. Basically, I have to bring the car back to Wheel Works and ask them to do it over with the front right wheel being brought forward a little more so I can regain turning radius and rectify the wheel well contact.
DOH!
Old Nov 17, 2006 | 11:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Is their a hitch on your bird or what?
Old Nov 18, 2006 | 02:18 AM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
That's just crazy!
Old Nov 18, 2006 | 02:44 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Bah, dirt bikes are the future, WE HAVE THE TECHNOLOGY!
Maybe if I was missing one nut and felt like doing some french garbage I'd totally pedal myself haha.
BTW the brakes look sweet Mike!
Old Nov 18, 2006 | 08:13 AM
Cadillac's Avatar
Have another cigarette, Vinny.
Oh wait. I'm the smoker.
No hitch on my car. That rack is just the most flexible with respect to fitting on cars. No scratches with the bike or rack installed back there. The rack is 50 bucks too!
I'll spend the rest of the day at the alignment shop it look like.
Old Nov 19, 2006 | 03:58 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I mean MTB is cool and all but I love hitting a nice hill climb / trail ride / jump with the 2 stroke wide open.
I guess my real problem is I like going fast and I don't even have a MTB haha. And like I said, pedal myself, that gets old.
That rack is sweet and congrats on getting the brakes done, you got to make her stop well before we do the motor swap.
Old Nov 22, 2006 | 11:08 PM
Mr. IROC-Z's Avatar
I have crashed pretty severly on my mountain bike (Broken wrist, twisted ankles, sprains, lots of cuts and bruises). If I ever road one of those dirt bikes, I would surely KILL myself...hehe.
Tommy
Old Nov 23, 2006 | 12:22 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Tommy
I've screwed my wrists up pretty good, bruised ribs, wind K.O. of me, some nice scars, but all in all it has made me a much better rider
Seriously though, for someone with a speed addiction such as myself, motorcycles are great because it feels like 200MPH when your flying down the dirt / street at 1/4 of the speed. The IROC is much more comfortable at triple digits.
MTB is cool as I said, but I love ripping it uphill as well as down haha.
Old Jan 17, 2008 | 05:50 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Re: Never goes as easy as you think: LS1 Brakes
So where can someone like me get these brakes
Old Jan 18, 2008 | 12:14 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Whoa right on welcome to last year!
To answer your question :
Old Jan 18, 2008 | 09:50 AM
Cadillac's Avatar
Sent you a PM.
Old Jan 18, 2008 | 11:10 AM
Engine: 350/350/LS1
I didn't get your pm
Old Jan 19, 2008 | 12:00 AM
Cadillac's Avatar
It was an email... You have PM's disabled. Well, you did this morning anyway.
Drop "ebmiller88" a note from this forum.
Old May 11, 2008 | 05:02 PM
lonesomecrow's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
where did you get this brakes and for how much?
Old May 11, 2008 | 10:24 PM
Cadillac's Avatar
Read post #36. Expect to spend around a grand.
Old May 11, 2008 | 10:38 PM
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
thanks man!
Old May 11, 2008 | 11:48 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I got complete LS1 front brakes for $40
Got to save some money for when I go on a Bilstein Bonanza $$$$$$
Old May 12, 2008 | 09:52 AM
Cadillac's Avatar
Pick and Pull, Vin?
Old May 12, 2008 | 03:36 PM
  #42
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
yeah I would like to know as well!
Old May 12, 2008 | 04:30 PM
  #43
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Basically I scored a complete K-mem from a guy who parted a 2000 Z28 for the motor / trans.
Cool for me because I wanted everything for the swap.
PNP would have been over $40 for just the 2 calipers.
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Jan 19, 2016 12:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
