Northern California Discussion board for Northern and Central California.
Need blocks rebuilt
Old Dec 6, 2006 | 06:27 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
Need blocks rebuilt
So I have a line on a 350 block to throw into my 91 TA (since we pulled the 305 out and its just sitting in my shed atm). I'm looking to get a stock rebuild on it for as cheap as possible --- not looking for new parts but to make it run nice. Every shop I call and talk to wants a ridiculous amount of $ for a stock rebuild!!! I've gotten from $1299 (non-roller) up to $1700!
What the hell should I do? Who wants to donate me a running 350?
Old Dec 7, 2006 | 06:09 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
those prices are retarted for a stock shortblock rebuild keep looking, try calling someplaces up here or beg jesasaurus to build it
Old Dec 7, 2006 | 12:12 PM
Russ-So Cal's Avatar
Those prices are not unreasonable. Most shops presume you want a guarrantee. They are not going to rebuild your engine with worn out used parts, and new parts and labor costs $$$. We have a bunch of shops here in So Cal that do cheap rebuilds. They keep Dyno Don busy fixing their screw ups. Fortunately for the guys who have given in to the temptation to buy one of the cheap rebuilds, the engines won't start after they are installed, so Don gets to go through them before permanent damage is done.
Old Dec 7, 2006 | 12:37 PM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
Ok, dont get defensive here. I bought this car for $400... and my goal for the car is to get it up and running reliably for as cheap as possible. I don't have a problem using good, used parts for cheaper. I'm not so concerned about a warranty in all honesty, but haven't thought about it much. I just wanted to spend about $600 - $800 and get a good stock rebuild. Is that too much to ask?
Old Dec 7, 2006 | 01:02 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Kragen Auto, I think they have long blocks for 799 with exchange. Probably wont find anything less expensive with a warranty.
Old Dec 7, 2006 | 02:33 PM
JesasaurusRex's Avatar
You provide the machine work and Ill put it together for free, being unemployed right now Itll pass the time and put another m*llet on the road.
If you're interested let me know.
Old Dec 7, 2006 | 05:02 PM
3.492rs's Avatar
Car: 89 IROCZ
see told u so nick, the man himself shows up
Old Dec 7, 2006 | 05:03 PM
MiTHRiL's Avatar
Engine: LT1, L98
Axle/Gears: 3:23
got lucky
Old Dec 7, 2006 | 07:40 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
can't beat that deal, and his car is a couple turns of the carb from 10's
Old Dec 7, 2006 | 09:05 PM
PM sent back
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DARKmj16
Sep 9, 2015 04:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
