I need a tire hook up!
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Hey fellas, do any of you have a good hookup on tires? I need 2 Falken FK451's in a 285/35/18. I know they're discontinued but I am trying to find them somewhere. The FK 452 will work too but they're more expensive. I might also do a set of 4 tires (doesn't matter what brand) but I will need 2 - 245/40/18 front and 2 - 285/35/18 rear. I don't want to spend another $1,000 on tires so the cheaper the better right now. Thanks guys.
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
well i don't have anymore hookup on tires. but on tirerack they have sumitomo htrz 2 for $162 each for 285/35/zr18 and $94 each for 245/40/zr18
Car: 00 Camaro SS
Engine: 5.7
Yeah I was looking at those and that's a possibility. I just wanted to see if I could find something a little cheaper. Plus they're out of stock on the 245/40's.
Car: 1991 Formula L98
Axle/Gears: 3.73:1
It's going to be tough finding something cheaper in those sizes. Let me know if you do find something because Nitto 555's are fairly expensive, the cheapest I've found is tires.com for about $230 a pop. I wonder how traction is on those Sumitomo's, I mean, I know they're just street tires so they will be designed to wear slower and won't be the best with a lot of power on tap. I am probably going to run slicks at the track so I don't really want to run an expensive DR that I'll be wearing out every 3k miles either.
Car: 00 Camaro SS
Engine: 5.7
Yeah the fk452's I would be getting are areound 245 each so I want something cheaper. The ones on tire rack I would get but I would have to figure out a different size for the front.
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I don't know if this is true but I heard American tires matches or can beat tirerack.com prices. may be worth a shot
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
What is American Tire? I have never heard of them. I will be needing some new rubber soon. I still have to figure what 18" wheels to get.
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Car: 00 Camaro SS
Engine: 5.7
Well the FK452's are 193 there. I really only need the 2 rears as the 265's will just be moved to the front.
Engine: 383/LGX
Engine: 383/LGX
have you thought about a 275/40/18 more common size then the 285/35 and is pretty much the same height 26"
2MNYMaros
Sep 15, 2015 11:36 PM
84 TA NV
Sep 6, 2015 08:02 PM
