Northern California Discussion board for Northern and Central California.
headers got me fed up
Old Mar 26, 2007 | 03:26 PM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
headers got me fed up... vid added below
i am over having these ****king headers on my car. i dont know if its just my luck, consequences of having headers, the header brand, bad work done or what but i blew a 2nd exhaust gasket for the 2nd time in about a month in the exact same spot, a month after i got my stage 8's installed. im ready to trash these things and pee on them and reinstall stock exhaust manifolds
Old Mar 26, 2007 | 03:28 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Re: headers got me fed up
What brand are they? If it's on the mounting flange, it sounds like you have a warped flange.
Old Mar 26, 2007 | 04:20 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I agree, take the side in question off and put a level on the flange side to see how out of whack it is.
A lot of times the weld job on the primary tubes is a big blob and needs to be ground flush, or, the flange is warped and needs to be flat again.
I have done this before with the help of a sidewalk and a BFH.
You can always get a nice new set of headers, I'm guessing they're Blowtech, Dynocrap or Summit brand?
Old Mar 26, 2007 | 04:25 PM
they are edelbrock. the original owner installed em. i dont have the patience to get in the headers myself so a mechanic friend of mine does it at firestone for beer lol... maybe THATS the problem
Old Mar 26, 2007 | 04:30 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Old Mar 26, 2007 | 05:43 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Did you have them re-torqued?
Old Mar 26, 2007 | 06:02 PM
they are stage 8 locking header fasteners
Old Mar 26, 2007 | 10:36 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
what gaskets are u using?
Old Mar 27, 2007 | 01:31 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
felpro 1444 and be done with it, tes gaskets suk there like paper
Old Mar 27, 2007 | 03:05 AM
had metallic gaskets and that blew. then paper and that blew.
Old Mar 27, 2007 | 10:36 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
hmm.. i have the edelcrap tes headers they suck *** for peformance
but I have the 5.99 mrgasket header gaskets on there and standard bolts only have to tighten them up once in a while and ive had these on there for like 6K miles or somethin like that..
i think your flange is warped
Old Mar 28, 2007 | 02:18 AM
possibly... ill have my buddy check it out when he re-does the gasket on tues. yes tues. have to wait a whole damn week =(
Old Mar 28, 2007 | 05:25 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Definitely don't go with paper gaskets again after your friend checks the flange bro, please get copper or my personal favorite the "Dead Soft Aluminum" ones made by Percy.
They are well worth the extra coin for the aggravation you've obviously already experienced. I've ran these for years and have came back to loose / missing header bolts and it still sealed.
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 28, 2007 | 05:54 AM
ill check em out bro... by the way... when are you coming to tear my engine block down? the motor is sitting waiting for you in my garage
Old Mar 28, 2007 | 06:01 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
We might just have to schedule a gtg out Ron's way soon
Old Mar 28, 2007 | 10:49 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I'm in.
Old Mar 30, 2007 | 01:18 AM
nice yeah i was thinking about that. a small bbq to do a small engine tear down. the teardown probably wont talk that long anyway.
i decided to take some vids of the car while i did the alternator.
heres just a clip of the exhaust from the rear
not too bad for an LG4
http://www.youtube.com/watch?v=O6_tecAwgBk
and a clip of the engine with the loud **** tapping i here from the busted gasket
http://www.youtube.com/watch?v=kmFQMg-U5KM
Old Mar 30, 2007 | 01:48 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
ur car sounds like a lawnmower with those busted gaskets.
Old Mar 30, 2007 | 01:56 AM
lol hadnt thought of that, youre right it does haha
at least the second vid sounds better.
Old Mar 31, 2007 | 12:39 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I use the SCE copper gaskets. They have always worked great for me. Do check the flange. If it is warped (depending on where) you might need to straighten it, or have it welded up and have it resurfaced.
Anytime your changing out gaskets because they are blowing it is usually one of three things. Either the exhaust system is hitting the ground and causing the bolts to loosen up and or compress the gaskets a bit further when it hits, since you said you have the stage * fasteners I do not think it is a loose bolt example, or the flange is warped.
Those are the only things that cause header gaskets to blow. Of coarse cheap paper gaskets can cause an issue too.
Old Mar 31, 2007 | 10:00 AM
Cadillac's Avatar
Dang it!~ I wish this thread would hve been around a couple weeks ago. I'm going with the TES gasket and a prayer. I'll be working on the car in an hour.
Antips16
Oct 30, 2015 06:42 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
FED 387
Sep 16, 2015 12:18 PM
gta892000
Sep 16, 2015 12:40 AM
