Northern California Discussion board for Northern and Central California.
Tranny trouble
Old Jun 28, 2007 | 12:17 AM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
Tranny trouble
The other day I had to fix a leak on my transmission, the tv cable on the tranny side was leaking so I got the new o-ring and put it on. I had to take the pan off and take the metal rod that goes from the cable to a spring, put the o-ring on and reassembled it reset the tv cable and now when it shifts from 1 to 2 i can't feel the shift and it slips. 2 to 3 and 3 to 4 is not that bad. Also when i get on it it goes to redline and insted of shifting to the next gear it slips down a 1000 rpm and then shifts. I have no clue whats going on.
Old Jun 28, 2007 | 12:31 AM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Re: Tranny trouble
the TV cable is most likely misadjusted after the repair. Give me a call at my cell and I'll walk you through how to adjust.
Old Jun 28, 2007 | 10:51 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: Tranny trouble
DON'T DELAY in getting it set correctly; apparently it'll eat up a tranny real quick!!! Nitro
Old Jun 29, 2007 | 12:08 AM
1TUF92Z's Avatar
Re: Tranny trouble
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
mrbird
Oct 20, 2015 03:43 AM
bjpotter
Oct 4, 2015 07:48 PM
Lmancha96
Sep 25, 2015 08:11 PM
IROCZ1989
Sep 4, 2015 11:54 AM
