Northern California Discussion board for Northern and Central California.
98-02 3.42 10 bolt housing/axles 4 sale
Old Jul 10, 2007 | 10:32 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
sup guys i just finished up my rear end. as many of u guys know i busted my rear end. At first i thought my whole ring gear came loose, but when i took out my differential cover my ring and pinion gear were still intack and in great shape ( no knicks or missing teeths). in fact 4 bolts heads that screws into the ring gear itself were sheared off. which caused my drivetrain noise. Im selling this rear complete minus the backing plates and an axle vent tube and differential cover since the old cover has a hole in it from the bolt heads. free pick up only. i'll try to take some pics of it. from the looks of it, you could probably get away by just replacing the posi unit, but i suggest taking the rear to rearend specialties in santa clara. they do awesome work.
Old Jul 11, 2007 | 10:56 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: 98-02 3.42 10 bolt housing/axles 4 sale
Got pictures of the 9" Installed yet?
Old Jul 12, 2007 | 09:18 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
sure do ./ btw terrell im gonna ship out ur driveshaft tomorrow
Old Jul 12, 2007 | 10:21 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Is that the housing and the axle? Looks clean.
What's a 3.42 posi unit run. Something like 350 or so, right? I could put my drums on there, right?
Old Jul 13, 2007 | 12:10 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
mike, those pics are my moser 9 inch. well on my 10 bolt both ring and pinion gears are in great shape. no knicks or missing teeth on any of them. Only thing that u probably need is the carrier. 4 bolts on the carrier has been sheared off, which busted a hole in my differential cover. i saw some rebuilt eaton on ebay going for 200 bucks. http://cgi.ebay.com/ebaymotors/REBUI...QQcmdZViewItem
i also recommend to replaces the axle bearings and seals, since they were in bad shape to begin with. like i said if u serious about buying this rear, take it to the differential shop before u buy it. i'll roll with ya. btw i dunno if they will fit ur drum brakes, u might have to convert to rear disc brake setup and u need to buy soem backing plates for the 10 bolt since i reused my stockers
Old Jul 13, 2007 | 09:32 PM
Comp788's Avatar
Looks nice
Old Jul 14, 2007 | 10:25 AM
Cadillac's Avatar
Yep... Brett is right. That Moser does look nice.
With the additional rebuild concerns, drum issues, and extra 2 inch width I'll have to pass.
The search continues... (timing isn't right either)
Old Jul 14, 2007 | 10:26 AM
JesasaurusRex's Avatar
I HAVE A 3.73 REAR END STILL!!!!!!!!!!!
Old Jul 15, 2007 | 12:46 AM
Cadillac's Avatar
I WANT A 3.42.. Or maybe a 3.27
I thought I've been clear about this. 3.73 is just too high for my needs.
Old Jul 15, 2007 | 12:57 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
mike why don't you just buy some gears and a posi and have them installed?
Old Aug 2, 2007 | 08:34 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
ttt. changed the price. its free now. somebody get this thing off my hands. all it need is a center chunk and new bearings n seals
evilstuie
Apr 14, 2016 08:52 PM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
