Oil Psi.
Car: 91 Camaro RS
Axle/Gears: stock
Oil Psi.
Hey guys. With normal 10-30 in my car on a fully warm day is idling with the psi needle on the white line under the 30 psi mark. It never goes into the red and scales with RPM. Is this normal for a stock L03? thanks guys.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: Oil Psi.
That's about what mine does. You oughta to ask the guys this question in the TBI forum?
Where are you located?
Car: 91 Camaro RS
Axle/Gears: stock
Re: Oil Psi.
im in Los Banos CA. K I guess I was just paranoid. I asked in the general tech forum and didnt get a hit. So I thought id try you guys. Thanks alot for the reply.
skinny z
Oct 5, 2015 06:23 PM
