Smog law questions
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Smog law questions
Hi I am moving to CA (Beale AFB) next nov and need to get some help on the smog laws before I swap the motor I am building into the car. First off, do collector plate car have to be smoged? What are the mileage limits on a collector plate car? If I don't do collector plates will I have to top my 383 motor with the crappy CFI I have in it now? or could I go carbed with a EGR equipped intake? How big of a cam can I run and still pass? If i cannot go carb'd could I just go to a normal tbi setup since it is still fuel injected?
oh and I can't find a emmisions sticker under the hood. Where would I get 1?
Thanks!
Thanks!
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Smog law questions
are you on active duty ? if so just keep it registered where it is , or maybe your home of record . california is a S.O.B. on emissions . cant help on collector plates . i couldn't get them for a 50 year HARLEY when i lived in chula juana .
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dont think CA has collector plates. Yes you can update an 82-83 CFI intake to an 82-87 carb intake, as long as you have everything hooked up and working correctly, either with stock parts or with 50-state legal parts. You can pass with a 383 as long as the camshaft is not huge. We're running TPI and passing with 224/232 cams, but that's with extensive chip tuning. I dunno how tough it is to tune a quadrajet to pass. You dont want to put a TBI on it, that's almost impossible with a 383 unless you really know how to chip tune.
Emissions stickers are no longer available new.
Car: 1982 Z28
I am on active duty now but will be in the national guard when I move so I don't know if that will cut it. I figure I will get the car tested here right before I swap it and that should buy me about a year and a half before I have to do something in CA. The lady at the DMV told me that I can't even get the car tested without a sticker? I guess I will proceed as planned and just keep all of the smog stuff for test days.
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
any car can be tested w/o the underhood label.
Car: 1982 Z28
are you saying that without the sticker I am F'd?
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Car: 87 Trans Am
Transmission: TKO 600
I'm originally from CT and I finally brought my car for a Pre Test @ Smog n Go last month. It passed the Tail Pipe Test which suprised me because of the Hot Cam and my minimal tuning(no egr in bin because of my holley SR I used to have ). The Guy there said I just have to put the Carb EO stickers on for the aftermarket parts and lower the idle for the timing check. I already knew my cold air intake would'nt pass so I'm gonna get and SLP Cold Air. I expected to fail but it was'nt that bad.
Car: 1982 Z28
Thats encouraging. I am thinking of running a xe274 cam. If I have to take the cam out to pass the test it wouldn't be as bad as changing back to CFI if they wouldn't let me pass with a carb.
don't need an under hood label
