Northern California Discussion board for Northern and Central California.
so slow!!
Old Mar 31, 2008 | 07:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
so slow!!
Common guys wheres the action today? its monday!
Everyone must be at work
I ran out of things to do today on the iroc and now I sit here board...
In lighter news, I have only one more chemo session left! and after that, one more bone marrow test to double-make-sure the cancer is gone for good. Then I can return to work, I will get a petscan about every six months for the next 5 years to keep checking up on myself.
Should be sweet soon, no more chemo, back to work, iroc is done, save money, and go racing!
Old Mar 31, 2008 | 08:15 PM
r1maniac's Avatar
Car: 2006 yamaha r1 50th anniversary
Engine: 1.0 ;)
Re: so slow!!
sounds like a plan man!!! good to hear your almost done with the chemo that must be a relief. i cant wait to see the iroc run that thing better be really deep in the 10s or better when your done.
Old Mar 31, 2008 | 08:18 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: so slow!!
I was gona do an oil change on the busa today, but was really to tired to do anything after the 250+ miles I put in yesterday on the busa.
header bolts on the passenger side of the formula are loose, and I cant seem to get to the last 3 in the back.
Old Mar 31, 2008 | 08:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: so slow!!
Ya I remember looking at that engine bay of yours, Eff that.
Old Mar 31, 2008 | 10:35 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Re: so slow!!
A/C deletes help out a bunch!
Old Mar 31, 2008 | 11:38 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: so slow!!
This weekend I completely replaced all the wear items and flushed the condenser and evaporator on my ac... New compressor, evaporator, orifice tube and pressure sensors. Pain in the *** to work around but man it is ice cold now. Also got new rotors for the front and am going to change the pads to ceramic this week, went with carbon metallic about 1000 miles ago, and Hate them.
Old Apr 1, 2008 | 12:56 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Re: so slow!!
Just got off work... Still no thridgen in sight for me (atleast untill i pay off the truck) Hopefully i will get stationed down in San Diego... good to hear that your doin good there travis... Anywho just poped in to say hey.
Old Apr 1, 2008 | 01:52 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: so slow!!
What did you hate about the carbon metallics? I think I have those on my car, but havnt had the luxury of driving with them yet..
I have to go look and see what I really bought, its only been about a year since I did all new brakes.
Old Apr 1, 2008 | 02:07 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: so slow!!
I finally picked up my new engine this evening after 10 months of middle finger tappping. I sure hope the old turd will get me to the GTG- Now I've got to decide on what colors to paint the block, heads, and intake and how much grinding to do on the new block to smooth it out.....
I still havn't started using my new MOATES tuning system and software, so will just have to box it up and bring it with me. Got my used set of Recaro seat brackets roughed in and hooked up the MSD ignition parts. I now have to pull the aluminum driveshaft out to rebuild and balance as I'm getting a severe Clunking noise shifting into drive or reverse. Either the new tranny or the new rear has extra play and neither shop will admit to it till I can eliminate the driveshaft play.
At least the tyres will chirp shifting into 2nd gear now. Initially I could hardly get the 350 to burn out in gravel...... Nitro- Nicky
Oh, I finally blew my three wins in a row at Infinion by breaking out early last week and only have 5 more NHRA points events to qualify for the track team it the regional November finals in Nevada- I sit at the 21st spot on that list.
Old Apr 1, 2008 | 04:10 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Re: so slow!!
The prolem with the carbon metalics is if they are cold the just dont work. I made it a habbit of draging the breaks for the first 200' or so after i pull out of my driveway, to heat them up and the were ok, but get on the freeway and cruse for 20 min or so and slow down on a off ramp and wala no breaks.
Also when they are hot they dont fade, but they are real grabby, Hard to hold the edge of brakeing and lockup. Would rather have a fade then no breaks, you can feel the fade comeing on. And ceramic disapate heat much faster, and have almost the heat rateing of Carbon Metalics., also they are fine cold.
I am keeping the pads, may try them if i decide to autocross, but for anything else not worth it.
Old Apr 18, 2008 | 05:31 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
Re: so slow!!
Welcome to the Busa' world. did not know you got one....
Old Apr 18, 2008 | 05:45 PM
kairles's Avatar
Engine: 383/LGX
Re: so slow!!
holyshit, what's up. what you been up to?
yeah I got a 2006 LE, had it for almost 2 years.
Old Apr 18, 2008 | 10:35 PM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Re: so slow!!
damnnnn, IROCDADDY is back on the board!!!!!!! Where have you been? I have tried to get a hold of you few times but no luck. Nice to hear from you again.
Old Apr 18, 2008 | 11:33 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: so slow!!
I'm debating putting Travis' old K&N back on the TBI and re-installing the valve cover breather. Maybe another 4* of timing too after I remove the block off plate on the power bulge hood.
I LOVE THIS STPUID CAR!
Old Apr 19, 2008 | 02:02 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Re: so slow!!
how have you been
so traviz is your final chemo over
Old Apr 19, 2008 | 02:05 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: so slow!!
yes it is thanks for asking.
just a few checkups on my blood count and i should be good to go!
But don't expect me to have a new look on life or anything. Save that for the movies.
Of coarse I respect you thirdgenners much more now Especially the guys that came to visit me in the hospital!
RedLeader289
May 28, 2019 01:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
