Northern California Discussion board for Northern and Central California.
Air/Smog Pump
Old Apr 8, 2008 | 05:14 PM
kahless's Avatar
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
Air/Smog Pump
I have a horrible noise coming from my smog pump!!!! It is making a grinding sound and it is really noticeable when you are giving it gas, My question is i was thinking of removing the pump and gettin a delete pulley for it. Can i just install the pulley and leave the tubing and black box there or do i have to remove the tubing and and plug up the holes on the manifolds??
Old Apr 8, 2008 | 08:25 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: Air/Smog Pump
Ever plan on passing smog testing again? If not, yank it. If so, replace it.
Old Apr 8, 2008 | 08:37 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Air/Smog Pump
Like Mike said, If you need to smog, better off replacing it, if you don't want to smog, get the delete pulley. Don't worry about the rest of the pipes, you can yank those out as well if you go the delete route.
On second thought, with just the purchase of a new belt, you can reroute it with the smog pump removed and everything else will function as normal, I did this a while back.
Old Apr 11, 2008 | 02:59 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Air/Smog Pump
yes and you can leave everything attached the valves on the smog tubes are one way so if no pump is pumping then your all good.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
