Northern California Discussion board for Northern and Central California.
New Mod!
Old Jun 19, 2008 | 08:24 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
New Mod!
here is the Mod that i have been waiting to do. Just did it this past weekend right before the Track. Im pretty sure it made a difference just not sure how much. I can feel it pull a little more on the top end. Once Marc gets his dyno put in then i can test it with the STOCK TPI intake and compare with the new setup.
Old Jun 19, 2008 | 10:31 PM
Vash Vega's Avatar
Car: 1990 Iroc Z,2004 Z06 Corvette
Engine: 5.7 L98 tpi/LS6 346 ci
Transmission: 700r4/MN12
Axle/Gears: 10 bolt 3.23/DTE 3.42
Re: New Mod!
im jealous i love the ls1 swap looks good im going to do that also when i swap in a ls1,how much it cost to do that
Old Jun 19, 2008 | 11:40 PM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Re: New Mod!
Looks like 12.653 @ 108mph The dyno is at the shop right now. We are taking extensive measurements for the dyno placement. It's not light where we can just roll it around. It took the whole rocklin crew to push the thing around. Should be up and running within 10 days.
Old Jun 20, 2008 | 12:07 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Re: New Mod!
That sounds great! Time for Dyno day!!! I wish it was 12.6!! Some day Bennie some day.
Kidd, if you got time and da money, the sky is the limit. The cold air intake was $130.00 i had to make it myself. Still some parts i need to fix. And its not Cali legal! OH WELL!!
Old Jun 22, 2008 | 05:33 AM
Cali Z's Avatar
Re: New Mod!
Your setting up a dyno in Rocklin?
Old Jun 25, 2008 | 04:06 PM
Vash Vega's Avatar
Re: New Mod!
Hey Ramair do you have pics of your exhaust,undercarriage
Old Jun 25, 2008 | 04:14 PM
Stephen's Avatar
Car: 87 GTA
Re: New Mod!
Why'd you build it as a hot air intake though?
For just a little more work, you could make it a COLD air intake...
Old Jun 26, 2008 | 12:18 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Re: New Mod!
Making this is way better then having the old TPI setup i had going for me. So this is a pretty good improvement. But im going to make a another one just like yours but out of aluminum. You should move your MAF a little closer to the filter. get that out of the way of the heat
Old Jun 26, 2008 | 12:23 AM
Stephen's Avatar
Car: 87 GTA
Re: New Mod!
It's not my white car, but a friends 92 Camaro.
Old Jun 27, 2008 | 11:04 PM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: New Mod!
[quote=Ramair21;3796652]That sounds great! Time for Dyno day!!! I wish it was 12.6!! Some day Bennie some day.
Not to brag, but even when you run a 12.4, (like me) its not enough. Enjoy your run. Put some spray on it & you'll be in the low 11's
Dyno close to being done.
Old Jun 28, 2008 | 12:55 AM
1TUF92Z's Avatar
Re: New Mod!
Not fast enough until you see a single digit before the decimal point...LOL
Old Jun 28, 2008 | 11:44 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Re: New Mod!
I know the time will never be enough but i reached my goal on my Stock LS1.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
