question about smog
Car: 1990 Iroc Z,2004 Z06 Corvette
Engine: 5.7 L98 tpi/LS6 346 ci
Transmission: 700r4/MN12
Axle/Gears: 10 bolt 3.23/DTE 3.42
question about smog
I will be getting my car smog soon and i wanted to know if i would pass with a stock l98 with 24 pound injectors, should i buy a afpr and adjust the fuel pressure or does the stock prom compensate it enough to where it's not running rich
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: question about smog
If the smog tech sees an adjustable fuel pressure regulator, that will be an instant fail.
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
the ecm needs to know it has 24lb injectors otherwise youll be running pig rich ,
bump down the fp and you loose fuel atomisation so loose loose situation
my suggestion a chip with the fuel injector rating changed, and than nice healthy cat....
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
tech left the A/C on, didnt check timing right, and put N/A for EGR. Trending Topics
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
i took my 87 305tpi to get it smogged. only had a new 3" magnaflow cat, a new O2, 24lb accel injectors with STOCK prom and i passed no problem. before with the old O2 it ran rich, now my plugs are a nice tan colored so im saying its around the normal
here are my results HC@15mph= 48 HC@25mph= 40 CO%@15= .04 CO%@25 .01
NO@15mph= 256 no@24= 230
Engine: 383/LGX
so i should go to a test only station and see if it passes, who burns prom's around here in sacramento
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
24 lbs injector are fine. It's not gonna run rich. If it's running rich, it's not because your running 24lbs injectors.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It really depends on the rest of your engine. If your O2 sensor is in good shape, you'll probably pass ok. But with the bigger injectors and the stock prom you will be running rich upon acceleration and wide open throttle.
and for the record, 24# injectors are NOT smog legal!!
Fuel injectors are a "stock replacement part" so they're fine. Just dont mention to the tech you've changed them and save the hassle. If the tech asks any questions just say either "Its all stock" or "it came that way when I bought it." If he gives you further hassle just go somewhere else. Some techs wont touch a modified car because they are afraid the state inspectors might be trying to test them and get them in trouble. Junior Member
Car: 85 TRANSAM
Engine: SB 400 6.6liter
Transmission: IROCZ 5sp w/ Racing Clutch
Axle/Gears: 3.18
is there gona be any smog problems by swapping my 305 to 350 if i have all the original equipment to put on like stock exhaust, manifold, arir cleaner, cat????
