Nor-Cal '09 1/4 Mile Track Times
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
It's that time of year again, so let's see if we can get a more respectable list going for 2009.
3rd gens only
Please provide your complete data in the format below in order to have it posted, thanks!
1. First name (Username) - 1/4.X @ XXX.X mph - X.X 60ft - Year - Make/Model - Engine Size - Power Adder (if applies)
1. Brian (EvilCartman) - 10.65@122.94mph - 1.49 60' - 1982 Camaro Z28 - 350 - Nitrous
2. Marc (3rdBird) 11.43 @ 123.86mph - 1.68 60ft - 1991 Firebird - 406
3. Bennie (1TUF92Z) 11.52 @ 120.629mph - 1.608 60ft - 1992 Camaro Z28 - 406
4. Del (OUTATIME GTA) 12.6 @ 111mph - 1.83 60ft - 1989 GTA Trans Am - 350 - Supercharged
5. Joey (Ramair21) 12.9 @ 106mph - 1.77 60ft - 1989 Camaro - 2000 LS1 Motor
6. Aaron (Bullydawg) 13.7 @ 101.3mph - 2.2 60ft - 1988 - Pontiac Formula - 357
3rd gens only
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Nor-Cal '09 1/4 Mile Track Times
For the record:
'08
1. Brian (EvilCartman) - 10.49@126 mph - 1.42 60' - 1982 Camaro Z28 - 350 - Nitrous
2. Bennie (1TUF92Z) - 11.5@119mph - 1.XX 60' - 1992 Camaro Z28 - 406
3. Marc (3rdBird) - 12.2@105 - 1.64 60' - 1991 Firebird Formula - 350 - Nitrous
'07
1. Armando (valencia1z) - 11.68 @ 117mph 1.72 60ft - '86 Iroc - 350 - TPI - nitrous(100)
2. Del (OUTATIME GTA) - 13.3 @ 107mph 2.0 60ft - '89 GTA - 350 - TPI - Supercharged
3. Joey (Ramair21) - 13.5 @ 100mph - Z28 - LS1
'06
1. Jesse - 11.14 @ 129
2. Armando - 11.9 @ 116 (nitrous)
3. Brian - 12.51 @ 108
'08
'07
'06
Car: '89 GTA
4 year record still goin strong at #2
Dang, I sure take my time dropping tenths, eesh.
'06 - 13.5 -> '07 - 13.3 -> '08 12.9
If history repeats itself, the best I can get is a 12.7 this year, haha.
Anybody have a time to post yet? I know some of you savages have been out there since Feb and earlier.
Car: '89 GTA
<cricket sounds>
We're almost in June, anybody have some times to report??
You can enjoy the luxury of being in the top 3 very easily!
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That was my first time out there. My best trap was a 103 run. I couldn't get any traction.
I plan on going out over summer at least 2 times a month if my formy is running. I don't have to work part time anymore. I can't wait to graduate in 4 days!
faster et than you @ faster mph than you - faster 60ft than you - sbc - 1989 Chevrolet Camaro - 1 stage plate no controller
i'll take #1
i'll take #1
Car: '89 GTA
Go ahead Jess and fill in those figures accurately and I'll get you up there in that # 1 spot.
Otherwise. ..
Sounds good Brian.
Otherwise. ..
Sounds good Brian.
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
I'll take the #2 spot
Haven't taken Jolly at the track....going this coming saturday. We'll see.
wheres your friend turd bird? doesn't want the #1 spot or what?
Everybody wants No.1 spot so I give up, I'll just follow.
I need to update my ignition, I can't spin my motor over 6400. If it's fuel then I will definitely need to transfer the motor to my other Camaro. Or Firebird?
Hope it works out
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Hey Del, Mark me down
Joey (Ramair21) 12.9 @ 106mph - 1.77 60ft - 89 Camaro - 00 LS1
Unfortunately no 10 second pass for me but....
11.520 et @ 120.629 mph 1.608 60' 406 all motor stock rear end w/3.23 Still working on a few problems.
Eliminated 5 Mustangs until 2 Mustangs and 5 Camaros. I was supposed to run a Mustang again but I ended up racing a Tub Camaro. Only If we didn't change my dial in of 11.80(ran 11.67), I would have still won the race. My son was with me and learn how the bracket race goes and asked why did I have to change it. I said I didn't, someone did......he then said aagain......WHY???
I just did some calculation and if I am right which I think I am, I would have still lost the race even if dial in was not changed due to my slower reaction time.
Car: Camaro RS/SS
Engine: 5.7 LS1
Great Job Bennie!! Sorry i didnt say good bye. The fam was ready to leave after i lost the 4th race. Glad to hear that some mustang butts got kicked.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How is everyone getting traction out there? I had new nitto drag radials and I cut ONE 2.1, but it was hot out and I ran a 14.1... Then as I cooled down I cut a 2.2 and ran a 13.7... What PSI is everyone using?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I was at about 20 PSI at the track. The first run I didn't turn down the PSI at all and it was at like 32PSI and I did a small burn out and I cut my best 2.1 and that was the hottest part of the day too. At 20 PSI with big burnouts, I cut a few 2.1's, few 2.2's 2.3 and a 2.4...
Car: '89 GTA
I would think with that higher stall and new DR's you should be able to cut some 1.8-1.9 60's at least.
With my old BFG's and not really smoking the tires, I was typically 1.9-2.0 with 15-18psi in them and that's not very good.
I'm in the market for some new "streetable" DR's and hopefully some better launching skills, hah.
Hey Joey, were those 1.77's with the same slicks?
Car: '02 Z06
Engine: L33 5.7
try even as low as 15. I think your just in need of more launching practice. no amount of tire can help your torque off the line.
First of all, before everyone start suggesting tire pressure. What size tire is it?
Car: '82 Z28
Try this, quicky roll into the throttle instead of just hammering it.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
The drag radials are the Nitto 555's that are 245s.
Anyone want to let me try there tires sometime?
#42
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How should I launch it then? I doing a fat burnout in the beginning, then foot braking to 2400 or so, then rolled on the pedal, and still had traction issues. I tried launching in 1st, 2nd, and in drive... not much difference.
I went on a Wednesday night without much prep and really hot outside.
#44
Car: '82 Z28
Lower your RPM and let the converter flash, maybe a little less of a burnout. Hey, you should head up to Redding on the 27th. Gates open at 6pm (usually open earlier though) and racing starts around 7pm ish. It's about the same driving distance as Sacramento and it's only 5-10 bucks to get in, another 10 to run.
#45
Car: Camaro RS/SS
Engine: 5.7 LS1
#46
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
#47
Car: '82 Z28
Doh. I'm hoping to do a cam swap Friday so I'm hoping to get the car back on the road soon as the lifters come in lol. Hope I ordered the right length pushrods or else I'm screwed for Saturday.
#48
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
3rdbird, 11.87, @ 120.78 mph, 1.70 60' 91 Firebird, 406ci, no bottle.
#50
Cool...go..go..go. It's about time. I like competition. I need to install that coil and try to break low 11's. You're close to my time or I can just press that "detuned" botton. j/k.
Car has been ready to hit the track months ago but, it's been busy at the shop lately. Few more tweaks and it should break into 10's. Then we will give the baby bottle. The last time we hit the track on the car was like I think 4 months ago.
