Northern California Discussion board for Northern and Central California.
Had a grin on my face today...............................
Old May 2, 2009 | 06:05 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My car needs paint. And an alignment for that matter. Looks like I'm game for tomorrow though.
Old May 2, 2009 | 06:18 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Had a grin on my face today...............................
fukkk you jacked my wheels bro
nice choice
Old May 2, 2009 | 06:26 PM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
Nice, see ya tomorrow!
Old May 3, 2009 | 11:12 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Looks awesome Andy! Can't wait to do the same!
Where did you buy the kit? Did you swap prop valves? Braided lines too?
How much of an improvement do you feel in the pedal / stop difference?
Old May 3, 2009 | 11:18 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
At the GTG, he said he didn't need to swap the prop valve. He got some stuff from EBmiller I think.
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i dont know about anyone else but i sort of like that blue fender. dont know why.
nice brakes but they dont look like they will fit 15 inch rims.
Old May 3, 2009 | 11:38 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Old May 4, 2009 | 01:13 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
The difference is very noticeable. I will be honest however, it's not as drastic as I was expecting based on the way everybody on the brake forum creams their pants over their brake upgrades. This is most likely due to me sticking with standard pads and stock rubber lines. I'm sure performance pads and braided would make the difference you're after. I'm also still "breaking them in". The rotor had a coating that you need to dig through with a couple days of driving.
The best thing about them is I don't feel like I'm taxing them under normal use. I drove around town for 30 minutes, pulled over, and I could rest my finger on the caliper, it was barely warm to the touch! Tells you something about how hard they have to work to stop the car. I remember how hot the stock ones were one time I touched them.
Still definitely 100% worth it. Looks badass too. C5 kit requires 17" wheels. For 16" wheels look at the LS1 kit. If you have 18" wheels he has some kits that make these C5s look like child's play, like the 6 piston C6 ZO6 and Caddy CTS-V!
I still have the factory disk/drum prop valve. Not sure what to say about that, everything seems to work fine and the rears don't lock up prematurely.
I got the parts from Ed Miller. Quality of the parts is top notch, however it took much longer than expected for him to get them out to me. Paid Feb 24th, just got everything this week.
Old May 4, 2009 | 01:26 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Awesome, thanks for the great review!
I've heard I have to swap prop valves because I have the factory rear iron calpiers. Weird.
That is quite the turnaround time from Ed, did you order them from him on here through PM or his flynbye website?
Old May 4, 2009 | 01:12 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I have an adjustable prop valve.
Old May 4, 2009 | 02:02 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
From where Travis? . ..or are you bs'n.
I was discussing adjustable prop valves with Bennie recently since both our brakes didn't tend to hold very well at the track. He has a nice little vacuum/brake setup to handle his now I think.
I've replaced the OEM calipers (including the PBR rears) within the past year and have decent pads/rotors, but I'm still not able to hold my rpms as high as I probably should.
Old May 4, 2009 | 02:18 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
its a wilwood, it was on my car yesterday. cool little *** lets you adjust front to rear bias.
Old May 4, 2009 | 02:24 PM
Car: '89 GTA
How does it feel? Have you messed around with it enough to notice the control?
Old May 4, 2009 | 02:59 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How much did that little sucker cost ya? I would like one also...
Old May 4, 2009 | 03:02 PM
Car: '89 GTA
They are ~$40, I just wasn't sure if they actually do the trick.
http://store.summitracing.com/partde...5&autoview=sku
Just found a how-to as well. ..
https://www.thirdgen.org/propvalve
92GTA
Apr 9, 2016 07:39 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 2, 2015 03:39 PM
