What cam do you run?
Car: 1986 IROC-Z
Im thinking of putting a new cam in the iroc.
How well does your car pass smog with it?
Post any video clips, i want to hear idle also!
decisions decisions!
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: What cam do you run?
What cam do u currently run? What type of power are you looking to put down? Idle characteristics? Got any idea... I run a hotcam, I have a new Crane CompuCam. Never installed. dont remember the Duration figures, but it provides a .454/.480 lift, if interested let me know.
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
218/224 @ .050 comp xfi268 passed smog here with no problems, on the stock tune. Most aftermarket cams are going to require at least mild head work and springs to handle the lift.
Car: 1986 IROC-Z
id be looking twards something similar to narcal's. ability to run stock tune and without major engine work
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
original lb9 cam from my 85 iroc (spun rod) in a 84 crapper 350 with crapper 882 heads all under my almost stock tpi. man that thing ripps!
put this thing together for ***** and giggles with a t-10
boy was i surprised!and it smogged, almost failed at idle, had to get the exhaust supper hot!
boy was i surprised!and it smogged, almost failed at idle, had to get the exhaust supper hot! Last edited by vasquezmrysvll; Jul 8, 2010 at 10:29 PM. Reason: 1
1988iroc350tpi
Aug 14, 2015 07:52 PM
