Got my compression check finally... Time for a new Engine...
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Cylinder 1: 100
Cylinder 3: 75
Ouch. 2500 miles from my car in Biloxi, Ms... then to Wichita Fall, Tx in 2 months...
She's going to be down for some time now. Imma invest in a newish truck, and save my pennies for a while.
but on the bright side, I ran a 13.1 cutting a 1.8 with 2 low compression cylinders...
Cylinder 3: 75
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: Got my compression check finally... Time for a new Engine...
ha.. got any ideas what you think you wanna run this time? Still never figured out the crankcase pressure ordeal either huh?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Haha, maybe she just wants that Ls1 I was talking about, and figured she would kill this one so she can move on to LsX. I have 4 choices... Lsx (which I want), 383 stroker (best build I can easily get being 2500 miles from home, or a simple rebuild and bore (would only need boring, pistons and rings), or park her and move on and get back to her when I get out of the Air Force.
As for the crankcase pressure.. Im going to assume for now I have scratches in the cylinder walls allowing pressure to leak into the crankcase, causing the leaks and too much oil pressure.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Imma go for a practical and reasonable build... and for times??? Reasonable ones.
My father and I have decided on a plan. Should be coming with me to my first duty station. Drive there should be a nice break in period. I'm going to start collecting the parts, and have everything ready, then while on rap, and a bit of leave I am going to do the swap.
