Northern California Discussion board for Northern and Central California.
need help with my 92 camaro Rs
Old Aug 25, 2011 | 10:25 PM
Chevyrider408's Avatar
Car: 92 Camaro RS
Engine: 5.0
hey guys i'm having some problem with my rs. for some odd reason it wont turn on. i took the battery and starter to get tested and it passed. all my light in and out of my car turns on. does anybody have any idea what it could be?
Old Aug 25, 2011 | 10:39 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: need help with my 92 camaro Rs
"wont turn on" is too broad of a statement for anyone to help you
Old Aug 25, 2011 | 10:48 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
check the ACC fues. If that blows your car wont turn over.
Old Aug 25, 2011 | 11:01 PM
Car: 92 Camaro RS
Engine: 5.0
sorry , so when i try turning my car on the car doesn't turn over. it doesn't make any sound what so ever
Old Aug 25, 2011 | 11:02 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
is the car cranking but not starting? or is it not even cranking? if it isnt cranking. and the battery and starter tested good, you need to check if your getting power to the starter. our cars have a Vehicle anti theft system. The lil black pellet in your key, it is possible that system known as VATS has failed. Thier is only so much we can tell you over a forum. But IMO your best bet is taking it to an auto shop and they can have you going in no time.
Old Aug 26, 2011 | 01:18 AM
Car: 92 Camaro RS
Engine: 5.0
its not even cranking. but your the second person that has told me about the key. I'm going to check that out. thanks
Old Aug 26, 2011 | 03:48 AM
Kraz-z's Avatar
Car: 91 z28
Engine: 305 tpi
my 2 cents. i had this problem and it was a fuseble link between the bat and a starter. nothing came on and it wouldnt crank
Old Aug 26, 2011 | 09:40 AM
enragedyouth85's Avatar
Car: 1989 Chevy Camaro RS
Engine: 305 TBI
Transmission: Standard 5-speed
Axle/Gears: Stock
I had this exact same problem in my 89 Camaro, I drove it to the store and came back out and blam! The car didn't start, it would turn on the radio, lights etc when I turned the key over but no turning over the engine. Took it to the garrage and they said it was my ignition, I belive they said my ignition coil pretty much fell apart when they took my ignition apart. So I would have them test your ignition system, it's probably your ignition coil inside your steering column.
Old Aug 26, 2011 | 10:45 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Its very possible. look into it. I would tell you how to start the car by bypassing that but you have to ground two wires together and I dont want you to do the wrong one's and burn something up.
very possible also!
Old Aug 26, 2011 | 06:18 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
igniton coil = underhood
ignition SWITCH = on top of column
Old Aug 26, 2011 | 09:42 PM
Engine: 305 TBI
Axle/Gears: Stock
There we go lol ill have to see if i have the repair bill still..
Old Aug 27, 2011 | 01:55 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
ignition module=underhood inside distributor
Old Aug 27, 2011 | 08:05 PM
Engine: 305 TBI
Axle/Gears: Stock
No repair bill but it was def something in my ignition system, inside my steering column! I remember because I had to take it back because he didnt tighten my turn signal screw down enough and my highs got stuck on lol
Old Aug 27, 2011 | 09:51 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
ignition lock cylinder, ignition switch
Old Aug 27, 2011 | 11:10 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I was coming back from the beach one year never had a problem with my car not starting. We stopped at a store and when I came back out the car would not turnover. I had to get it towed almost 200 miles home. I didn't have time to work on it for a few weeks. I would go outside and turn the switch to see if if would work nothing. The day I went out to see if I could fix it I told my brother one last time we will see if it will start BAM it started! I drove the car for a good year then I replaced the switch because it broke. It was the wire that goes to the anti-theft was pinched. I didn't find that out until the switch broke and I had to replace it.
Old Aug 28, 2011 | 12:36 AM
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
Been their, done that .......what P.I.T.A.
Old Aug 28, 2011 | 06:48 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well they sell VATS bypass modules and stuff. But my car was almost stolen and VATS saved it. Amateur thieves though.
Old Sep 10, 2011 | 11:48 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
One thing we should all carry in our 3rd Gen tool kit is a basic Test Meter with extra long lead addapters that can be easily picked up at any Radio Shack.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
