Northern California Discussion board for Northern and Central California.
Someone please help!!
Old Sep 8, 2011 | 03:36 PM
89flyboy's Avatar
Car: 85 trans am, 77 t/a
Engine: 5.0 TPI, 6.6 400
Transmission: Auto, 4 speed
I have a 85 trans am 305 TPI with a 700R4 tranny. I am trying to get it smogged and I have a egr vacuum part that is on the passenger side between my valve cover and my intake. My lines to it have been cut, everywhere I look I can not find a new one listed or even where the damn hoses plug into the intake or egr. I only posted it here instead of the main board cuz ya'll would no about smog.
Thanks,
Josh
Old Sep 8, 2011 | 05:35 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: Someone please help!!
Are they hard lines or rubber? Sounds like your egr solenoid lines to me. One end goes into your top nipple o. Egr valve, other line goes to more vacuum up front, look under your TB and see if there is a hose attached to it. The egr solenoid Line should be t- connected there. Post pics if you can.
Old Sep 8, 2011 | 08:12 PM
89flyboy's Avatar
the book calls it a egr solenoid. There are two nipples for rubber lines in the rear and two plastic hard lines in the front I will try and post some pics. I tried calling Marc and Bennie, Marc said he would call me back, left a message for Bennie but never heard back.
Old Sep 8, 2011 | 09:03 PM
Copchaser's Avatar
Is the solenoid connected to an electrical clip in the harness? So ur saying they clipped it at the back ( the end where the electrical connection is)? The end with the connector goes toward the rear of motor.
Old Sep 10, 2011 | 08:46 AM
89flyboy's Avatar
I got the vacuum diagram from autozones site so I figured out where everything is suppose to go except the hose on the back of the soleniod. They did not clip the wires but they had broken the hard line plastic hoses off. Now I got all the vacuum lines ran right and was setting my timing and the car died just out of the blue and wont start again. I turned the key off and back on and I don't hear a fuel pump whine or anything. The fuel pump is only a year or less old. the only thing that was not changed was the fuel pump relay so I changed that and still nothing, and it has 3/4 of a tank of gas. I even took a small screw driver and pressed on the pressure fitting on the fuel rail to see if it was getting fuel and again nothing.
Old Sep 10, 2011 | 02:04 PM
89flyboy's Avatar
I wonder if its this issue?????? https://www.thirdgen.org/forums/tpi/...regarding.html
Old Sep 10, 2011 | 08:26 PM
Copchaser's Avatar
Wait about 5 minutes in between key off and key on procedures to make sure ur pump primes. If still nothing, check fuses, then wiring connections. If still nothing...... You may wanna call one of our well sought after mechanics here on the forum.
Old Sep 10, 2011 | 11:37 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Hi Flyboy- just to add to the good advice already given and to clarify. Did everything, including the fuel pump work until you messed with that particular passenger side area? That's where your fuel pressure regulater clips in and is why I'm asking. If it worked before, than logically you bumped something.
Do you own a 3rd Gen and not own a 3rd gen specific repair manual? If you do, let us know which one you DO have so we can reference specific pages, okay?
Old Sep 11, 2011 | 12:35 PM
Copchaser's Avatar
Old Sep 13, 2011 | 09:47 PM
89flyboy's Avatar
I do have a Manuel for it and everything was working even after messing with the stuff on the passenger side. I called the PO and he said that everything was replaced but the relay so I replaced the relay and still nothing I checked all the fuses and they are all good. I waited till the next day thinking it maybe related to the other thread I posted and still can't hear the pump and still won't start the car came with a extra ecm so I tried that sense I was not getting any check engine light with the key turned to the on position and still nothing guess I will be dropping the tank, for a new pump. Anyone in vacaville wanna help with a pump on a tank that is 3/4 of a tank full??? Lol
Thanks,
Josh
Old Sep 13, 2011 | 10:02 PM
Copchaser's Avatar
Hold on a second... U are not getting anything when u go from key off to key on? No fuel pump, check engine light... Does anything light up? Do ur gauges respond to power (battery voltage reading) does radio turn on.? Before u go dropping the tank, BE ABSOLUTELY SURE thats the problem. If ur getting nothing at the key, u may have N ignition switch problem, which would account for no fuel pump response. Or a dead or under charged battery.
Old Sep 13, 2011 | 10:12 PM
89flyboy's Avatar
Correct I am only getting a seatbelt light but that's all I was getting before and the car ran great. The key still goes through all the postions and has spring tention to pop it outta the start function. I have a hard time thinking its a switch or a ecm when everything was working perfectly till just all of a sudden it died but I could be wrong here my other project is a 2nd gen so the computer stuff is all new to me lol.
Old Sep 13, 2011 | 10:23 PM
Copchaser's Avatar
Ur check engine light should come.on EVERY time u go key off to.key on. Then go off while u.crank, then off after car starts, unless ecm detects an issue. I would investigate that first. Attacking these little gremlins could solve ur fuel pump issue down the road.
Old Sep 13, 2011 | 10:25 PM
89flyboy's Avatar
Ok thanks for all of your help hopefully i can figure this out soon I really wanna drive it before the rain starts.
Old Sep 25, 2011 | 12:00 PM
89flyboy's Avatar
Ok so update, I had an extra ECM laying around so I swapped them out and turned the key on, still nothing. I got into it to look at the ignition switch and it looks brand new. I loosened the gauge cluster and found out there ones no light bulb where my check engine light is, so I put one in, still no light or pump noise. I read in my book that to check the fuel pump you can run a battery supply wire to the G terminal of the ALDL so I am gonna try that next. Man I have two T/A's and can't drive either of them I am dieing here lol.
Josh
Old Sep 25, 2011 | 12:40 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I think its a 20 amp fuse by the battery for the ecm check that.
Old Sep 25, 2011 | 01:43 PM
89flyboy's Avatar
The fuses are all checked and good I wonder if the check engine light issue is do to the circuit board its all seperating. But I am still trying to figure out why my pump died it was working just fine and then I bumped the starter to mark my timing mark on the crank so it would be easier to see and then the pump just wouldn't work again IDK why it was working perfectly and the pump is less then a year old.
Old Sep 25, 2011 | 01:48 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Easy explanation : electric fuel pumps die
Especially if it was replaced with a cheapo, had one die in less than that time period
If you think the pump is guaranteed good jumper it at the connector at the tank and if it still doesn't come on, it's dead. Please don't cut an access hole.
Old Sep 25, 2011 | 02:01 PM
89flyboy's Avatar
It is an Autozone pump I have never had issues with them before, maybe a factory dud? Idk I already have the exhause off I am going to have to drop the tank and replace it, oh well I read the leads should be replaced at the same time maybe they were not done and that could cause the problem?? I also tried running my canister hoses the right way maybe that killed it lol. This is why my other T/A is a 77
Old Sep 25, 2011 | 04:34 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Unless you replaced it with a Walbro (reboxed as Holley Edelbrock etc.) then you bought a junker for probably ~$50 and I'm surprised it lasted that long, vatozone parts are no bueno
Like I said try putting 12v to the plug for the pump @ the tank, that bypasses all the wiring bullshit
Old Sep 30, 2011 | 11:04 AM
89flyboy's Avatar
Thanks for all of the help guys. I ran a jumper wire from the battery to the G terminal of the ALDL and the pump worked so I need to grab my Ohms meter and start checking volts at connections to find out where my issue is coming from.
Old Sep 30, 2011 | 12:19 PM
Copchaser's Avatar
sounds like a short. Glad you are making progress. Let us know the outcome.
Old Sep 30, 2011 | 12:39 PM
89flyboy's Avatar
Will do I hate checking wires and running them. Seems like I will miss this cruising season but next year she will be ready and good to go lol.
Old Oct 3, 2011 | 09:47 AM
89flyboy's Avatar
Update I reran the jumper wire and wiggled the pig tail running to the fuel pump relay and the pump died even with it jumpered, maybe I need a new pig tail. I also hear air in the system when the pump is running but no fuel leaking out???? Maybe a regulator??? But that was changed under a year ago. Any ideas???
Thanks,
Josh
Old Oct 3, 2011 | 12:06 PM
Copchaser's Avatar
Not sure I follow ur last post. If u got power direct from the battery, then ur pump is fine. Do continuity test through your wiring to find the short. Test your relay and make sure it is working properly. By what u are saying, it seems as though you have loose wire, causing an open in the circuit and therefore not getting power to a perfectly fine fuel pump. Double check your grounds also.
Old Oct 6, 2011 | 05:27 PM
89flyboy's Avatar
I had the jumper wire ran straight from my battery to the G terminal of the OBD1 (ALDL) connector like my Haynes manual said to do to check pump flow, and the pump was running. While it was jumped I wiggled the wires that ran into my relay and the pump died. So I took off the pig tail and the wires inside were all loose and black. I took some electrical parts cleaner and cleaned them off. Then I took a flat head and repaired the connection the best I could (GM wants 65 dollars for the new connector. Hooked it back up and she purrs like a kitten, got the timing set, need to finish welding the exhaust up and then she will go to smog (fingers crossed)
Thanks for all the help and ideas,
Josh
Old Oct 6, 2011 | 09:09 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
3rd gen relays are pandora's box, they work and are never touched or go completely haywire.
I'd say since you've found the prob, which is pretty common, and fixed it (right on) just keep an eye out for another relay at picknpull and snag a spare or maybe a relay / connector combo and splice it in.
Good luck with SMOG (you're gonna need it)
Old Oct 8, 2011 | 10:04 AM
89flyboy's Avatar
Ya smog makes me very nervous this car sat for over a yr I know I just need a connector and I can order one through Orielly for 17.00 (GM wants 65) But I am on a budget so that will have to wait. Thanks for all of the help everyone.
Old Oct 9, 2011 | 11:38 AM
Copchaser's Avatar
Glad u got it fixed, good work good luck with the smog!
Old Oct 18, 2011 | 12:06 PM
89flyboy's Avatar
Ok so I got a 60 day temp tag on Friday and have been driving her sense. I took her for a pre-check yesterday. On the way a saw a guy with a red 89 GTA and told him about this group. The smog guy said my numbers were high but still in legal limits. The only thing that failed was the pressure in the evap system. He said he didn't hear any leaking up front so it maybe by or on the tank.Wish I woulda known that before I welded up my exhaust. So now its time to chase hoses.
Old Oct 18, 2011 | 01:56 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
a paid diagnostic is gonna be your fastest way, take it to a smog machine and let them use the smoke machine. i wouldnt pay more than $120 in a diag fee.
Old Oct 18, 2011 | 02:47 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I bet you the tank is cracked around where the filler neck meets the tank, thats where mine was. And since I am super lazy and dont wanna pull or buy a new tank, i got some of the gas tank epoxy and smeared it all around and got her done...haha...still holding 3 years later
Old Oct 18, 2011 | 04:19 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
^what he said.
Old Oct 18, 2011 | 08:28 PM
Copchaser's Avatar
Or jb weld
Old Oct 18, 2011 | 09:18 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
that works, the stuff i used was designed specifically for fuel tank repairs and is available at auto parts store..but I am only assuming that is where his leak is, could be somewhere else.
Old Nov 13, 2011 | 11:04 AM
89flyboy's Avatar
Ok its been a while sense I updated this thread I got it checked out and found out it was the seal on top of the gas tank. So back out went the exhaust DANG IT and the rear end was dropped and everything. Got the tank out and seal replaced. As I was putting the tank back in I broke the pressure relief valve so I had to find a new one of those. Thank goodness for Pick-n-pull. Now when I take off the gas cap I get a pressure release sound.....Sweet sound of victory. But now when I drive I get a whine from my rear end???? This is turning into the one thing leads to another project. But at this rate I will have a brand new car lol.
Old Nov 14, 2011 | 01:02 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Welcome to thirdgen ownership!
Old Nov 14, 2011 | 09:01 AM
89flyboy's Avatar
Lol third gen or just car ownership? My 2nd gen is the same way. But its ok now that I am divorced she can take my money instead of a woman ROTFL.
Old Nov 27, 2011 | 01:24 PM
89flyboy's Avatar
Well it happened again. I went to 7 eleven to get a drink the other day came out tried to start her and just rotates no fuel pump. Had her towed home and ran the jumper again and the pump works. I spend a afternoon in Stockton getting parts came home replaced the fuel pump relay again and the pig tail still nothing. I was told there maybe a shutoff switch on the fuel rail on the passenger side fuel rail that tells the ECM when the fuel rail is primed to kill the pump. I have two parts that screw into my fuel rail one looks like a fuel filter, it has a screw in nipple on the one end and a wire coming off the back end, and another that looks like a oil pressure switch that has two wires running to it. I unplugged them both and still no pump on key on but when I rotate it it catches but doesn't fully start........Guess its back to the drawing board.
Old Nov 27, 2011 | 06:19 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
there is no such sensor that tells the ecm when the fuel rails are primed. It is strictly on a 2-3second timer to have the fuel pump prime for. What you unplugged is the fuel pressure regulator and the other sensor is probably the air temp sensor under your plenum, not in the fuel rail.
Old Nov 27, 2011 | 08:21 PM
Copchaser's Avatar
Check ur MAF burnoff relay. It tells the fuel pump when to turn on.
