Northern California Discussion board for Northern and Central California.
Good luck passing smog
Old Dec 6, 2011 | 01:54 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
The guy that just tested my GTA said they lowered the pass numbers 30% Dec 1, 2011. Looks like he was right.
Here are the pass numbers from Jan 2010
AT 15 mph AT 25 mph
HC CO NO HC CO NO
108 0.71 767 83 0.58 706
Here are the new numbers
76 0.50 537 58 0.40 494
I failed both HCs and the 15mph NO. I would have passed with flying colors at the old numbers.
Old Dec 6, 2011 | 02:08 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: Good luck passing smog
I've heard of this silly smog ritual. Bummer to those needing to pass it.
Old Dec 6, 2011 | 02:09 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Hmm, maybe now is the time I need to go to cali with a big car hauler haha. Start buying up cars that wont pass.
Old Dec 6, 2011 | 03:22 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah that worries me also. you have the right to own any car you want, but we will try and do anything we can to make you get a different car. haha. freaking politics and BS!
Old Dec 6, 2011 | 04:36 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
If my car emits the same as it did at the last test (10/29/2010), I'd still smack those numbers down:
Results last test- 26, .01, 91; 19, .03, 35.
Of course, I did just jinx myself.
The only thing that was different then, than my current sig, is the torque converter.
But, when I test again 10/2012, I could be looking at tighter yet target numbers.
Bill
Old Dec 6, 2011 | 06:32 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
its achievable, mostly im sure has to do with the fact they want people to replace their cats more often.
Old Dec 6, 2011 | 07:19 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Damn that just made me worry about my z28 for my smog
Old Dec 6, 2011 | 08:30 PM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
Time to start thinkin about a PO box up in the hills mine hasn been registered since 2009 i dont wanna pay a pigs salary anyways jus get the insurance lol.
Old Dec 6, 2011 | 09:09 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yet they make the cat manufacturers of universal converters give a 5 year 50k mile warranty?
that does not make sense to me. That warranty is a cop out. I am kind of looking forward to seeing if they even stick to it. because in thier eyes a converter should last 5 years no problem unless the car is running bad. which then it wouldnt be covered. It's all BS. I hate this state.
Old Dec 6, 2011 | 11:57 PM
webeeZ28's Avatar
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
AT 15 mph AT 25 mph
HC CO NO HC CO NO
Holy she-ite. I just barely passed the end of August. How much lower will they go 2 years from now?
Thanks for the update injdinjn. Please let us know what you had to do on your car to pass these new specs.
James
Old Dec 7, 2011 | 10:51 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Bill
Damn Bill,
I thought mine were good....
Just checked my last #s
10 .00 199 11 .00 200
It pays to do things right.
A good tuner helps.
Old Dec 7, 2011 | 11:35 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
well my ebl flash should help some. i just think it i bs.
Old Dec 7, 2011 | 12:15 PM
Unleashed Jimmy's Avatar
Car: 82 Converted IROC
Engine: 350ci TPI
Axle/Gears: 3.23 10-Bolt
This sucks. Figures that politicians would figure out a way that makes the air cleaner and polutes the land fills and costs us more money.
Old Jan 8, 2012 | 01:39 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Matched combos can pass very cleanly. Mine passed the second smog with lower numbers than it did when the combo was brand new. Not too worried about it.
Old Jan 8, 2012 | 04:07 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
well thats good Will is that car tuned yet?
Old Jan 18, 2012 | 07:14 AM
XitLeft's Avatar
Car: '88 Chevy Camaro. T-Tops.
Engine: 2.8L V-6 (yea, it cruises nice !)
Transmission: 700-R4
Axle/Gears: 3:42's
Wow, mine is coming in August. How would we start something about this smog mess, like : My car was designed to pass required emissions for 1988, and runs fine, it is not designed to pass your more strengent emission requirements & should not be expected to.(it was not designed to) If it passes for what it was designed for, it should be left alone, and after it is 20 (25 or what ever) years old it should be exempt (reinstating rolling year rule, that was repealed). AND it gets them out of my damn pockets for the smog check !!
I realize the politicians don't give a damn about us, or our cars, but we should remind them WHO voted them into the office, and WHO can vote them OUT as well.
Old Jan 18, 2012 | 11:28 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
its all politics. and its all part of getting old cars off the road so people will buy the new stuff. but it'll pass and you'll be okay bill.
Old Jan 19, 2012 | 12:59 PM
XitLeft's Avatar
Axle/Gears: 3:42's
I hear you about the politics.
I sure hope it passes the smog this year.
Old Aug 1, 2012 | 09:45 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I need to get a used cat I almost passed with a gutted cat,I put my stock chip&injectors&sn2000 and turned my timming to 3 degrees dam almost made it.
Old Aug 1, 2012 | 09:47 PM
antoine's Avatar
Or if someone can let me use or sale me there takeoff
Old Aug 1, 2012 | 10:36 PM
Bounty Hunter's Avatar
Oh man...maybe its time I get both my cars swapped over to Alabama plates...
The RS barely passed a year ago ... and the IROC has straight pipes ...
Old Aug 3, 2012 | 03:35 PM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Just pay 160-250 to do smog your good well if u dnt mind payn the money.
Old Aug 4, 2012 | 12:01 PM
antoine's Avatar
I have the hookup on that
Old Aug 10, 2012 | 11:02 PM
zero16lives's Avatar
Car: 1989 Camaro RS
Engine: V6 2.8L
Transmission: 5 Speed Manual
i.just had mine tested about a month ago. it didn't pass but only because of the check engine light the emissions were fine. good luck to the rest of you though
onefreakz
May 14, 2018 12:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
bamaboy0323
Sep 3, 2015 06:07 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
