Back Floor Body Plug Metal Interior
Car: 95 camaro z/ 90. 350. irocz
Engine: lt1 on 95. 350 tpi on 88 iroc
Transmission: auto on both
Axle/Gears: 9 bolt On Iroc.10 on 95 Z
On the rear of my Camaro, I pulled back the rear carpet and found a little moisture under the carpet and also a little rust. I let the carpet dry and sanded rust away, primed and painted and top it all off I put undercoating. I found it was coming from the metal plug so I cleaned under and sprayed the undercoating to seal the metal plug with the undercoating. Going to check next week to see if there is any difference. Anyway, this is just a heads up. Do not want your third gen rusting away under your eyes. See you all.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Back Floor Body Plug Metal Interior
You mean in the trunk area? There are also these same plugs in each cavity well where the spare tire resides. Also the opposite side where our little keyed security compartment is. Check those as well.
Hi there. Yes trunk area. I did check the sides just a lot of dust.
1992 Trans Am
May 10, 2023 07:19 PM
