Northern California Discussion board for Northern and Central California.
Distributor question
Old Apr 2, 2013 | 10:42 PM
NorCalTransAm's Avatar
Car: 84 Trans Am
Engine: L69 305HO carb'd
Transmission: Built 700r4
Hi all I have a 84 trans am 5.0ho 700r4 I got a msd hei street fire dist with ignition box and canister coil and it has a vacuum advance and my stock is computer controlled can I run the msd I bought or will I have issues running that dist. If I can run it what do I do with the vacuum advance portion ? Do I just run vacuum from the manifold or carb? Thanks for the help
Old Apr 3, 2013 | 11:19 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Distributor question
if you have a computer controlled distibutor now..you really need a replacement one like it. im not that familiar with the early computers with carbs but everything works in unison with eachother. Now if you changed your carb to a regular holley, edelbrock, demon that wasn't computer controlled then you can run your setup. (it is probably better to do that, but it isn't smog legal)
Old Apr 3, 2013 | 05:15 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Smog legal is the key. Stick with an HEI cap distributor and save the headaches.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
