Northern California Discussion board for Northern and Central California.
Wrecking yard T5s?
Old Jan 12, 2014 | 10:36 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Wrecking yard T5s?
Does anyone know of a yard thirdgen with a 5-speed manual and electric VSS sender (my guess is '87 or newer)? My '86 T5 trans has the cable driven speedo and I'm trying to find the T5 VSS sender (#10456087). GM is out of stock nationwide, so if any of you are heading to the junkyard let me know if you find an electric one off the tailhousing of any T5s you come across, pull it and clip the harness (I'll need a foot of wire at least) and I'll pay you back. Gearing is not such a big deal as I can probably fix any inaccuracy with a Dakota Digital box, but if you new the year/rear end gears it came off of that'd make things a little easier as there wouldn't be as much guessing. Thanks!
Old Jan 20, 2014 | 03:09 AM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
Re: Wrecking yard T5s?
i have the pigtail grabbed i but dont need it with my swap. i will check my local yard i pulled my tq mount off a v6 t-5 out there i will see if its been crushed on tuesday.
Old Jan 20, 2014 | 02:58 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah I don't see the T5's out there too often and when I do they go fast. I guess someday I should pull everything out myself and try to resell it.
Old Jan 20, 2014 | 03:26 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
http://www.ebay.com/itm/T-56-CAMARO-SPEEDOMETER-GEAR-SENSOR-T56-T-56-GM-94-95-STICK-SHIFT-TRANSMISSION-/281242226288?pt=Motors_Car_Truck_Parts_Accessories&hash=item417b57ce70&vxp=mtr
Old Jan 20, 2014 | 05:30 PM
super_kev's Avatar
Car: '85 TA
Ok great, thanks guys.
F-body-fan
May 4, 2026 09:42 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
86IROC112
Nov 7, 2015 06:50 AM
tattmann
Sep 27, 2015 05:20 PM
armybyrd
Sep 26, 2015 03:37 PM
