Engine Tuning In Bay Area / Surrounding Areas
Hello All,
Just joined the forums here. I have a 92 Camaro with a 383 ZZ4 crate engine swapped in. Using TBI & Prom Chips.
Anyone out here tune these engines? It is running a little rough around the edges. No shops I have called are willing so far..
Im in Fremont, but willing to drive up to an hour or two away.
PM or call/text 5106734501 if you are a shop or are well versed!
Thanks in Advance
Dan
Thanks in Advance
Dan
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine Tuning In Bay Area / Surrounding Areas
Have you looked into dynamic efi ebl ?
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Mail order is basically your only option if you wanna keep the TBI.
Engine: Lb9
Transmission: M20
You might ask brian Harris at tbi chips.com if he has a tune for your setup.
If not you might want to talk to him about datalogging to get a better tune.
There is a used ebl for sale here
https://www.thirdgen.org/forums/engi...ified-tbi.html
H0TR0Dn
South Central Region
Feb 27, 2005 11:31 PM
91Zman
22
Sep 22, 2001 06:30 AM
