Flunking emissions
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Flunking emissions
I just failed emissions. My HC and CO were high
HC was 4.59 and the limit is 2.5
CO was 49.39 limit 20
WTF
It says that I might have unburnt fuel and there is a possibility of a rich (air/fuel) mixture.
Ok, whos got hook ups, or tips how to pass this tree hugging burocratic piece of **** test???
WTF
Car: 1992 RS 25th Anniversary
Engine: 305 TBI
Axle/Gears: 3.42 posi
I had a Tahoe that was high on both of those readings. I bought it from Wyoming so it had never been through emissions before. The EGR valve wound up being bad and was dumping **** back into the engine causing the high readings. I replaced it and drove it about a hundred miles to clear it out and it passed with flying colors. Good luck
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Had the same problem with my '92 a couple of months ago, turned out to be one bad fuel injector. Car ran fantastic but would'nt pass CAC dyno. Isn't Colorado wonderful?
You really should try to get the car on a scanner to see what's going on.
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
Did you make sure that you ran the engine long enough to get the cat hot before you went there? Do you have an AFPR on there? That was my problem. Turned it back to stock, flew through. O2 sensor might cause that as well. Any codes, Sasa? If it comes down to it, new plugs and wires MIGHT help, but not by much.
Car: 1987 Camaro,'89 firebird
Engine: 305 quadjet, 305 tbi
Axle/Gears: 2.73. 3.2xs
well you're not the only one having problems passing im planning on taking mine up there thursday and if it fails again im going to put in some e85 and then run it through.
COTM Editor
As Walt had mentioned the cat being too cold is a very common failure. There is so many cars that come into the shop that have small problems, but getting the cat smoking hot will sometimes temporarily mask these problems long enough to pass the test. If all else fails start checking the basic of the fuel control system, then move to emission control systems.
Thanks for the help guys.
I just got hotter platnum plugs (I know), I will change those tommorow. Also, I will run some denatured alcohol through the car as well. If both of those fail I will just have to get a waiver.
Here is the part about the emissions that pissed me off. When I brought the car in, the line was long. I had it on the whole time, but it stayed at 190. From there they finally brought my car in (in front of two other cars). So, I leave the car on, and the guy shuts it off. I go WTF! So, after about 20-25 minutes, they started my car again and ran it. I was afraid that this was gonna happen. However, these readings were waaay higher than the limit thus pointing to a problem.
I might as well replace all my injectors (since I planed on doing it anyway). However, I will try some alcohol and sure pass in there, and if I fail again... Look for alternatives.
Whats the point of emission testing, if you can pay 800 bucks and have it waived???? Fuking buerocrats.
My licesne plate is going to be ****EPA (if they let me), if not EPASUX. For sure.
Transmission: 4L80E/4L80E
Just a reminder, guys, that spelling words to circumvent the Board filters is against Board rules. The subject line has been altered to reflect the thread topic while staying in compliance with Board rules.
I'll be the first to admit enforcement hasn't been consistent. We're trying to be more so.
FWIW, DMV is even more picky about personalized plates. I'm quite certain neither of your suggested plates would pass muster.
There's ways around that
Wait and see, I have to pass emissions first though!
Oh, and I love "flunked emissions" makes me sound like a bad *** in high school, "flunking" classes.. \
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
before you shell out for new injectors id recomend sending them to Rich @ cruzin performance. He will clean, flow test, and replace and parts neccisary. I had him do mine and I was very satisfied. Took about a week to get them back tho, so if you are in a hurry might check and see what his schedule is like.
Cruzin Performance
Cruzin Performance
COTM Editor
Another place to check out is Linder Technical Services - Home of the "Injector Guru" They will sell reconditioned injectors for $24.95 each. We have used them at the shop multiple time for certain people that will not pay for new. Just recently had our first problem with one. It was two years old and started a very slight leak at the main body seal... called them and they overnighted a replacement.
Just a thought
Just a thought
Just the low vacum code at the map sensor. However, that has been fixed long time ago and the car did not throw any codes at me.
So, everything is working great (per the ECM).
I'll be troubleshooting more after our run tommorow/today.
COTM Editor
Were you using a scanner, or a code reader? If using a scanner the block learn will give you a pretty good indication of how much fuel it is using, and if the computer is commanding this fuel, or if it is attempting to remove extra fuel in closed loop.
Hotrodboba400
Dec 10, 2019 07:07 PM
