NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Busted taps :-(
Old Nov 24, 2004 | 09:03 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Busted taps :-(
Starter bolt hole was messed up on the new 383. No big deal right? Wrong! While tapping, I managed to crack the tap off in the block. Not a good situation at all. Good news to it was the fact that they do indeed make tap removers for this situation. I borrowed one from the machinist/eng builder and it worked out great.
Orignal problem was someone earlier down the line had mangled a thread way up in the hole, so when i went to tap it, it broke the entire thread out :-( Got the taps out and have the helicoil and bit to fix it and she should be as good as new.
No I'm not a rookie and I've tapped untol amounts of hole snad not once broken a tap of any size, let alone two like i did.
later
Jeremy
Old Nov 24, 2004 | 10:41 AM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
If I may make a suggestion:
Go to the boats tonight, that's some luck
Oh, and take a taxi
Old Nov 24, 2004 | 01:52 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I have never heard so many cuse words in the same on going sentance, when Jeremy broke that tap.
Kevin
Old Nov 24, 2004 | 01:57 PM
wrightz28's Avatar
Engine: L98, LB9
That's why if I have to go fix a car at someone else's house, and they ask: "do I need anything specialfor you to do the job (tools or parts)?"
Answer:
1-BEER
2-earplugs if you have religous neighbor's
Old Nov 24, 2004 | 05:43 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yep i found that with the offer of beer you can get more people to work on your cars then if you said i have cash. something about this magical beer thing that makes people want to come over and socialize then talk about cars.
Old Nov 24, 2004 | 07:28 PM
Slowmaro95's Avatar
From: Straight outta the red light district of Highland
Car: 2001 SS
Engine: guess...
Transmission: 4 spd w/OD
Axle/Gears: 3:73 Posi
Way to go slick!
Did they teach you that at Jag school
Just kiddin'.................Everyone have a good turkey-day!!
Old Nov 29, 2004 | 01:52 PM
3.8TransAM's Avatar
nope :-P
got all the busted tap out and then drilled it and used the all mighty helicoil and good as new :-)
yeahhhh me
later
Jeremy
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
steimel94
Sep 20, 2015 12:46 PM
gta892000
Sep 16, 2015 12:37 AM
dimented24x7
Sep 6, 2015 03:51 PM
