Starter Problems.......
Car: 91 Bird
Engine: 3.1 w00t
Transmission: 7hundo
Axle/Gears: bent
yea so i go to start my car today.......it starts and runs just fine
then when i turned it off.....i heard the starter motor continuing to try to engage....so i just disconnected the battery
wtf happened? that started is almost brand new
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Check to make sure none of the terminals on the starter are touching each other. I forget which terminals are labeled what, but none of them should be visibly touching each other I know.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Double check the terminals at the starter.....
Should only have B+ on the main cable from the battery with the key off.
Could be something shorted there to the ign b+ to the starter for cranking.
Or you could have a fubared ignition switch keeping it live at the starter when key off.
Check the basics first
later
Jeremy
later
Jeremy
Gunner242
Dec 25, 2015 04:49 PM
