paint question
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
paint question
jay will prob. be all over this one... my red car gets all chalky in the hood area really quickly and it water spots really easily. in the last 6 months, i've buffed and waxed it twice. it will look good initially, but within a couple of weeks, it starts getting dull and spotted... both times i buffed it, i used 3m finesse-it II. the first time i waxed it w/ nu-finish, the second time, i used black magic wet shine. are there any waxes that work better, or am i doomed to having red car chalkiness?
Car: 82 recaro ta
Engine: 305 crossfire
Transmission: 350 short
its hard to say. if its factory paint yr doomed. ive heard of painters useing cceap thinners and ruducers that will dull the paint faster. waxes dont work as a painter i would repaint the hood
it's been repainted once before i bought it, so i have no clue what was used... i need to respray the silver, so maybe i'll just paint the whole damn thing this summer...
thanks, though...
thanks, though...
Car: 85z28,
Man i wish i knew.. I'm still learning what causes what and why when it comes to paint..... Was it a single stage paint.That could dull out but not that fast.... The 3m finesse-it II is that a glaze? Cuz i use perfected 3 buffing compound.. That perfected 3 machine glaze. with a foampad.
Wish i could help out more
who makes perfected 3? how expensive is it? the finesse-it II, i'm assuming, is a glaze. it says "finishing material" on the bottle... the paint is base/clear...
Originally Posted by SOLOMOTORSPORTS
Perfect is made by 3M. and you need clear coat if you dont want that to happen again.
or it that an iteration of the perfected 3? Trending Topics
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
I'm certainly no expert on the subject, but this is what I know from experience:
Probably what is happening is the clear coat is breaking down, it will look like the paint is flaking and then get a whiteish, dull and dry effect to it. This can be caused by excellerated "normal" oxidation, or chemical reactions between pint and primer, or paint and clear.
Another cause to the same effect could be use of waxing compunds too soon after the reapaint and the paint did not fully harden ?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds like oxidation from not waxing/buffing enough. nothing you can do about it but wax more often to polish out the old oxidized clear. they probably shot a cheap maaco style clear that just doesn't have any durability.
