NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Help, Mr. Wizard!!!
Old Jun 12, 2006 | 12:56 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Help, Mr. Wizard!!!
https://www.thirdgen.org/forums/tpi/...nk-i-have.html
Old Jun 12, 2006 | 01:14 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it's not that hard. spend a day at it and be done. drop the rear shocks and watch the brake line and it'll drop far enough. don't forget to unattach the screws that hold in the piece around the gas tank
Old Jun 12, 2006 | 01:15 AM
watajob's Avatar
Car: 92 T/A 'vert
Do I have to disconnect the shocks?
Never mind. I didn't read your post close enough.
Old Jun 12, 2006 | 01:18 AM
xpndbl3's Avatar
Car: 1984 Z28
yup it's VERY VERY time consuming, get that car WAY into the air, but you'll do it no problem. don't forget PB blaster on all the bolts twice a day for a week before diassembly to help out with stuff breaking loose
Old Jun 12, 2006 | 01:27 AM
watajob's Avatar
Car: 92 T/A 'vert
And, LOTS of Bud Light!
Old Jun 12, 2006 | 01:53 AM
xpndbl3's Avatar
Car: 1984 Z28
beer....did someone mention beer.......if you only lived closer.
my car was built with beer
Old Jun 12, 2006 | 01:59 AM
watajob's Avatar
Car: 92 T/A 'vert
Hell! I can be in Orland Park in 45 minutes!
Old Jun 12, 2006 | 01:51 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
With 2 people i have done them in about 3 hours start to finish. Not too bad, getting the car high enough is the key to an easy job.
Old Jun 12, 2006 | 02:23 PM
watajob's Avatar
Car: 92 T/A 'vert
Help! (Again!)
Please see new post.
Old Jun 12, 2006 | 05:36 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
you just have no luck with this car
Old Jun 12, 2006 | 06:22 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
They take 3-4 hours not trying very hard.
Doesnt make a difference in the driveway on jackstands or using a lift.
Get the car up high and securely on 4 jackstands.
Unbolt the rear tires.
Unbolt the brake/fuel line cluster running up the drvr side of the tunnel all the way under the drvr seat.(gets that extra clearance to swing it out of your way.
Unbolt sway bar and panhard bar.
Unbolt shocks and use jack to lower rear end down far enough without dropping it out of the car :-)
Remove exhaust(unbolt at cat and shove it out over the pass disc)
Remove heat shields.
Unbolt tank
To remove tank it will need to be at about a 45 deg angle to the ground and you have to roll it towards you as you slide it out to clear the filler neck(dont beat on the filler neck or use excessive force, it will crack)
Replace pump(carefule of sending unit)
reverse and drive
Helps if u run it out or siphon the tank out, 20+ sloshing pounds of gas sucks to maneuver.
later
Jeremy
Old Jun 12, 2006 | 10:38 PM
paulbuiltbird's Avatar
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
these tips came at just the right time. I'm going to be upgrading my fuel pump soon. Anyone have any experience with the walbro pump kit from racetronix?
Old Jun 12, 2006 | 10:47 PM
xpndbl3's Avatar
Car: 1984 Z28
walbro pumps are nice and the racetronix seems to be a pretty sweet setup as well.
Old Jun 13, 2006 | 12:06 AM
3.8TransAM's Avatar
Shop for a Walbro.
Dont waste time buying it under any other name, u just pay more to get a repackaged Walbro.
Racetronix seems to have decent prices on them
later
Jeremy
1992Z28!
Nov 19, 2015 07:33 AM
sreZ28
Oct 22, 2015 08:21 AM
Stauf
Aug 24, 2015 08:31 PM
Mr. IROC-Z
Sep 26, 2001 11:09 AM
