NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Headliner fix writeup
Old Feb 10, 2008 | 10:54 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
Alright well i decided to fix my ttop headliner in my 1987 trans am since it was falling apart and in pretty bad shape. I decided to make a little write up on how i did everything and how everything went so others can do this as well. I was going to just buy a new headliner or abs one but i was looking at $230 shipped for one. And those had holes for seat belts and a dome light, which i didnt want.
So i went to Home Depot and picked up the supplies i would need. I bought 32oz of Fiberglass Resin, Fiberglass cloth, acetone, and the cheapest brushes i could find. If you plan on filling holes pick up some bondo as well. All the stuff i purchased cost me just under $30.
I then pulled the headliner out of the car and laid it on a plastic surface to work on. Heres what it looked like after i pulled it out.
Well as you can see mine was falling apart really bad. So decided that the best step was to get the underside cleaned off and remove the liner. Heres what it looks like after everything is cleaned off.
Once everything was clean i mixed up some fiberglass resin and hardener and added some acetone to thin out the resin so it would seep into the cardboard layers of the headliner. This will really make the headliner strong compared to how brittle the cardboard is. I let it sit and dry for about 2 hours.
I then mixed up some more resin with hardener, this time with very little acetone. I used this to get a thick coat over all the edges and places i was going to add the fiberglass cloth too. I then added the cloth and put another layer or resin to soak the cloth. I let this dry for another 2 hours. Heres what it looked like after coating it with resin.
continue to next post...
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Re: Headliner fix writeup
Notice how it still had the cloth on it. I left that on to hold everything together while i was fiberglassing the back side. The headliner is now MUCH sturdies that it was, its actually hard and can be handled without it falling apart. Now it is time to remove the cloth liner. Peel it all off and you are going to find a disgusting glue and foam mix that is super sticky. Here is what it looks like...
Now the best way i found to remove all this crap is by using a brush with stiff plastic bristles. DO NOT try to use your hand, it will just make a mess of your hand. This will take some time but is important. Once all the glue and padding is removed you can fill in any holes that you want with bondo. I mixed up a little bondo and hardner and added a little acetone to thin it just enough to get smooth coverage. Once applied let harden overnight. Here is a pic of the bondo filling in the overhead holes...
This is where it is currently at, check back after next weekend as i will be sanding the bondo smooth, fiberglassing the top with thinned resin, then applying glue and fabric to finish it up. Tim
Last edited by Smokin87TA; Feb 10, 2008 at 10:57 PM. Reason: Automerged Doublepost
Old Feb 10, 2008 | 10:57 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Saved for update.........
Last edited by Smokin87TA; Feb 10, 2008 at 11:00 PM. Reason: Automerged Doublepost
Old Feb 10, 2008 | 10:59 PM
Smokin87TA's Avatar
Car: 1987 Trans am
Engine: Cammin Ls1
Saved for another update.....
Old Feb 10, 2008 | 11:35 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
looking good, noticed my sail panels are coming undone need to look into this kind of stuff.
Old Feb 11, 2008 | 12:40 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Coo, look forward to seeing the final product as I have to do this on my 90
Old Mar 23, 2008 | 08:31 PM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
cant wait to see the rest of this write up!!!
Old Apr 9, 2008 | 10:06 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Bumpity Bump. Like to see how this turned out!
Old Apr 9, 2008 | 05:03 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Tim's been SUUUPPER busy with school and such the last few weeks. Not sure if he got around to putting the finishing touches on this.
Old Apr 9, 2008 | 05:25 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Excellent idea, i did this last summer to my berlinetta headliner. Excellent procedure and damn sure saves you $$$$ from ABS...stays more original, and you can do this in your garage in all of about a day. Do the fiberglass first to the cardboard so that it soaks in, that was the first thing i did on both sides. That alone is strong enough to man handle w/out bending, of which cloth to both sides just does that much more. Good luck and would really like to see end results!
Old Jul 27, 2008 | 08:11 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Did this ever get done? This is gonna be my project next weekend so Im curious to see how it came out
Old Jul 31, 2008 | 06:31 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
Bump, Also interested in how it turned out...
Old Jul 31, 2008 | 11:57 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
i started this today after i saw this last night and it is working phenominally. my only fear is that my headliner super rigid like i could throw it throw a window and im afraid that it is gonna be difficult to put it back in and it put it up right.
Old Aug 1, 2008 | 12:39 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
I also started this. Maybe have the actuall headliner fabric on by next week. the fiberglassing steps worked great though.
Old Sep 10, 2008 | 02:57 PM
92RSsleeper's Avatar
Car: 92 Camaro
Engine: 404 SBC
Transmission: The strongest stock T5 ever made
Axle/Gears: 3.73 w/Detriot Tru Trac Locker
bump...any finished pics?
Old Sep 10, 2008 | 03:56 PM
MrsDuronClocker's Avatar
Car: '98 Trans Am
I text messaged him, see if we can get an answer!
Old Sep 10, 2008 | 10:39 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
lol yup im another one getting ready to do something similar to this by the end of this year. wheres the best spot to get the headliner fabric? I went to jo-anns but didnt have exactly wat im looking for... I have a red interior on an 87 iroc (still dont know what the interior color is lol). I can put up pics but i want something very similiar to orginal color
Old Sep 11, 2008 | 09:20 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
My headliner has been sitting for awhile now. I still gotta buy the fabric lol. Sure is sturdy after fiberglassing though
Old Sep 11, 2008 | 10:29 PM
Car: 92 Camaro
Engine: 404 SBC
did you guys use fiberglass cloth on both sides? I coated the top with fiberglass resin and (and cloth only on broken spots) but it isn't seeing to dry....i did it last night...any guesses? I figure it's just not warm enough and I used waaaay too much resin lol.
Old Sep 11, 2008 | 11:03 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
did u dilute the resin mixture with asetone? i dont think it will make it dry any quicker but it made it a tad tinner so it absorbed into the liner better
Old Sep 11, 2008 | 11:08 PM
Car: 92 Camaro
Engine: 404 SBC
ya i actually did use acetone, more the second "batch" i made, but like I said...I used way too much I'm guessing. the factory headliners don't have a fiberglass top to them already right?
EDIT: I guess it would probably make a difference that I'm covering a hardtop, I know i heard about 2 hrs to dry..but that was with a ttop
Old Sep 12, 2008 | 10:49 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
it has a lot to do with ur mixture of resin to hardner.
Old Sep 12, 2008 | 12:12 PM
Car: 92 Camaro
Engine: 404 SBC
Sorry about hijacking your thread with all these questions.....
is it possible that if I didn't use enough hardener..that it just won't harden at all?
Old Sep 12, 2008 | 12:34 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
You probably didnt use enough hardner. Mine dried in like 5-10 min. I had to keep stirring it so it wouldnt paint on all clumpy
Old Sep 12, 2008 | 01:54 PM
Car: 92 Camaro
Engine: 404 SBC
well i guess that explains it, mine was thick, but i didnt feel like it was gonna harden on me immediately thx guys i'll let you know when it finally dries lol
EDIT: Do you think we could get this thread moved to the regular interior section? The beginning with pics is great for anyone trying to do this...and you can delete all my questions if you want haha
Veaceonee
Sep 29, 2016 08:15 PM
92firebirdguy
Sep 1, 2016 07:53 AM
PurelyPMD
May 5, 2016 04:57 PM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
