Vortec TPI base/slp runners/ported upper plenum zz4 cam,complete TPI setup basically.
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
scoggin dickey/edelbrock TPI baseplate for VORTEC/FASTBURN/ETEC/AFR heads or any head that has the 8 bolt vortec style manifold design, intake has mild porting to port match, its in mint shape.
SLP highflow intake runners, these are also port matched to the intake/plenum, they are also polished on the outside
upper lingenfelter plenum,port matched to runners/baseplate, this has also been polished
BBK adjustable fuel pressure regulator,works great no leaks no issues, holds adjustment very well
factory TPI fuel rails
factory tpi coolant neck and slp 180 thermostat
factory plenum extension/distributor cover
ARP hardware for every peice
GMPP zz4 roller cam
100% ready to run setup, runs great, only reason im letting it go is to go to higher RPM setup, its still on the car, runs and drives GREAT, pulls like a freight train
the polishing needs to be buffed with some mothers and a buffing wheel, thats all.
asking 650 obo{minus cam} or 725 with cam i dont need to sell, and i dont need the $$, willing to negotiate, but wont tolerate ignorant lowballing., will also include k&n throttle body mount air filter, and brand new SLP runner gaskets as i wont need either.
located on the southside,still on car, runs great no issues, but i am going with a miniram for my new setup.
Prefer local pickup/meetup, but will ship on the buyers dime.
Can post pics if needed.
GMPP zz4 roller cam
On Probation
Re: Vortec TPI base/slp runners/ported upper plenum zz4 cam,complete TPI setup basica
Update,went and took some pics...
they should be click to see highres 6 or 8 MP...
Car: 02 T/A
Transmission: Built 4L60E
Axle/Gears: 3.42 Posi
Is this set up still for sale? and how much horsepower and torque did this make?
Car: 1985 IROC
Engine: 350HO
Transmission: 5 speed
Axle/Gears: 10 bolt 3.23 limited slip
Didn't all this stuff get sold already in a previous post?
Terrell351
06-13-2021 01:13 PM
Sanjay
08-12-2015 03:41 PM
