NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Paint options
Old Feb 25, 2015 | 11:40 PM
bahsarie1's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 speed
Axle/Gears: 3.55
Paint options
So I got myself a vert and it could use a fresh coat of paint. Was wondering if anyone has any experience and what they paid?
thanks!
Old Mar 3, 2015 | 06:26 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: Paint options
To get a good job done, you're looking at 3-6k or more depending on how much prep work is needed. Save your pennies for a professional job. A 'stick shift 91 Z28 convertible is well worth it.
Old Mar 13, 2015 | 05:39 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: Paint options
What he said :-)
Paint isn't cheap, but I do suggest asking around at car shows on who did the work and what was done and how much it costs.
There are still a good number of guys who paint out of their houses around.
Also as mentioned it will depend on how much work it needs before the paint is applies.
Old Mar 13, 2015 | 06:00 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Paint options
To do the job right, with base/clear expect 2k minimum.
If you are willing to extend yourself and its not major work you can do most of the basic prep yourself and then just take it to a guy to lay the paint down.
Cheapest? I payed about $900 total for a single stage urethane paint job on my GTA. However, that was because money was tight, and quite simply the paint was in HORRIBLE condition. Clearcoat on all vertical surfaces was peeling. The car base coat was lifting on everything showing the primer underneath. In general, the only thing missing was exposed metal and rust.
9D1BURD and I replaced all of the panels that were damaged, did some basic body work under some instruction, primed those spots, and sent the car off to Maaco for the paintwork.
I would only recommend this if you want to avoid running around in a red-neck car.
The paint is about 5 years old now and still looks good. There are issues with it however. Its single stage. The paint is soft, rock chips are likely to dislodge a large chip of paint, especially at an edge. Thickness is not uniform.
If you can wait, wait to have more on hand for a real paint job.
Full album here. https://www.flickr.com/photos/855402...7631545655268/
To This.
Old Mar 16, 2015 | 07:26 AM
FBFAN's Avatar
Car: 91 Firebird
Engine: V-6
Re: Paint options
Your car looks great! Did you get the Urethane + IC?
Old Mar 18, 2015 | 03:47 PM
Re: Paint options
Its a simple color, so its not hard to do white. It needs a polish to shine again, but for the most part the major problem with it is the durability of it. Its simply too soft. small rock chip can cause a huge chunk to fly off.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 28, 2015 02:28 PM
TheExaminer
Sep 6, 2015 11:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
