OLD Third Gen Fest Discuss plans for the IL gathering set for May 27th-28th.
80/94 Road Construction Warning
Old May 26, 2004 | 01:16 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Please be advised of heavy roadwork along 80-94 from IL border thru NW IN
If u miss 394 south u will only be able to get off at Calumet of forced too Cline Ave to exit :-)
Might be nice to have a plan in place and a map handy in case u screw up :-)
This affects east and west bound drivers so dont say u werent warned
Route 30 in IL is also under construction as well as many other secondary and major roads in the area
thanks
Jeremy
Old May 27, 2004 | 10:48 AM
Guest
Guest
Posts: n/a
thanks for the heads up
Old May 27, 2004 | 01:52 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Its not too bad.
I've ridden out there with Tim when he goes to work on the bird. Just make sure that you have lots of change, because they closed down some of the manual booths and the lines get HUGE.
Old May 27, 2004 | 05:21 PM
SOX 19's Avatar
Car: 88 Formula, 01 Tundra
Engine: 305, 4.7 V8 17mpg
Found some more construction traffic too, on 94 from Michigan into Indiana today, took about an hour to get through, 3 lanes down to 1.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
lewandom
Oct 1, 2015 08:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
